| Kent |
Dec 20 2008, 11:39 PM
Newbie ![]() Group: Members Posts: 1 Joined: 20-December 08 From: Virginia Member No.: 9,865 Region Association: MidAtlantic Region |
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
| Red72 |
May 18 2015, 05:57 PM
Newbie ![]() Group: Members Posts: 25 Joined: 26-January 15 From: Simcoe, Ontario Member No.: 18,358 Region Association: Canada |
A bit of a ressurection here, but I'm having some 'challenges' with aligning my shifter after a bushing change (tail shifter). Presumably this method is common to tail and side shifters... But my question is if the splined shaft referenced is the forward shaft, connected to the shifter, or the rear shaft to the trans... Logic tells me it's the latter.
Thanks. |
Kent Gear shift adjustment Dec 20 2008, 11:39 PM
Racer Chris With the trans in neutral, attach a bungee from th... Dec 21 2008, 12:06 AM
jim_hoyland
With the trans in neutral, attach a bungee from t... Feb 1 2014, 09:42 PM
Racer Chris
With the trans in neutral, attach a bungee from ... Feb 2 2014, 08:33 AM
Bruce Hinds
With the trans in neutral, attach a bungee from t... Aug 19 2025, 03:46 PM
Joe Ricard Damn I have been screwing around with "one sp... Dec 24 2008, 09:02 PM
cpavlenko :shock1: :shock1: :shock1: that is so simple, I... Mar 11 2014, 10:06 PM
tomrev
A bit of a ressurection here, but I'm having ... May 18 2015, 06:44 PM
Red72
A bit of a ressurection here, but I'm having... May 21 2015, 12:01 PM
stugray Another trick I have learned (even if using Racer ... May 21 2015, 12:21 PM
Red72 So I'm now back to a point where I have first ... May 24 2015, 04:58 PM
Dr Evil Nope. The 4-5, 2-3 throws on a properly adjusted b... May 25 2015, 09:05 PM
Hine62 Where is the adjustment screw? I think R & 1st... Jun 8 2015, 01:11 PM
stugray
Where is the adjustment screw? I think R & 1s... Jun 8 2015, 05:06 PM
rgalla9146 Mark both pieces with a fine tip magic marker
put... Jun 8 2015, 06:37 PM
db9146 So mine is a tailshifter and I just finished repla... Jun 8 2015, 08:42 PM
Dave_Darling Sounds like you may need to adjust the lever over ... Jun 8 2015, 08:58 PM
RobW I use the put it wrong method, and then estimating... Jun 9 2015, 07:43 AM
Racer Chris
I use the put it wrong method, and then estimatin... Jun 9 2015, 08:48 AM
Dr Evil Put in 2nd. Disconnect shifter at rod (side shift)... Jun 9 2015, 07:42 PM
Bruce Hinds
Put in 2nd. Disconnect shifter at rod (side shift... Aug 19 2025, 08:48 PM
jdahl Need some help here, I've tried Dr. Evil and R... Dec 3 2016, 10:47 AM
Racer Chris
... and rotated spline by spline.
The splin... Dec 3 2016, 03:01 PM
SKL1 Get Chris' new front adjuster... just a satis... Dec 3 2016, 12:30 PM
Keith914 Check that nothing is preventing full left to righ... Dec 3 2016, 02:03 PM
Dave_Darling
Check that nothing is preventing full left to rig... Aug 19 2025, 07:07 PM
porschetub I continue to struggle with mine and think I'a... Dec 3 2016, 02:54 PM
Jack Standz There is an access hole towards the rear of the ca... Aug 19 2025, 06:55 PM
Bruce Hinds
There is an access hole towards the rear of the c... Aug 19 2025, 08:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 06:35 PM |
