Correct door gap between rear fender and the door. |
jkb944t |
May 21 2015, 05:31 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am in the process of replacing the section of fender shown below.
I am trying to line up the new fender section with the door correctly but I am not sure how to set the gap. What is the correct gap and will it be the same from the top of the door gap to the bottom. The gap seems to want to vary from about .185 at the top of the door to about .210 at the bottom. I could use some good input on how best to align this fender section and what is the correct gap before I weld it in place and tie it into the fender flare. Jeff B |
Kansas 914 |
May 21 2015, 08:06 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I could use some good input on how best to align this fender section and what is the correct gap before I weld it in place and tie it into the fender flare. Jeff B Do you have the correct rockers for a flared car? If so you might want to set them first as it will help determine where the fenders get placed. Others will chime in on the door gap. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:42 AM |
