GB -75-76 fuel line tank and filter kit, Inspired by my leaking hoses - $29 for 4 hoses and filter! |
Mikey914 |
May 5 2015, 04:15 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This includes -
The fuel filter 1- 12mm hose from pump to filter 1- 7mm hose from filter to tank 1- 7mm pump to engine line (connect to pump and delivery to engine plastic line) 1- 7mm return to tank line (other plastic hose into tank) The 12mm hose is a pain to find so I brought it in. These hoses are all made in Germany. Note the picture with the fuel pump is for illustration only. The second picture is what is in the GB I filled my tank for WCR a few days before the rally and when I came back out in the morning I only had a half tank, the other half was on the asphalt, what a mess. Attached thumbnail(s) |
Mikey914 |
May 22 2015, 01:23 PM
Yes these are the high pressure ones rated for ethanol.
Up on the site as if you replace the steering puck you should do these too. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:14 AM |
