| arsprod |
May 17 2015, 04:26 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
The temp gauge above my fuel gauge isn't working. For the life of me I cannot find any mention of it in the Haynes manual I have or even in the owners manual. Where's the sending unit for this thing? 74 2.0
| 914Sixer |
May 17 2015, 07:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,466 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Wire is green with red stripe. Heat and time have caused most of the wires to get brittle and break under the sheath giving you no reading at the gauge.
| arsprod |
May 23 2015, 11:28 AM
Wire is green with red stripe. Heat and time have caused most of the wires to get brittle and break under the sheath giving you no reading at the gauge. Could it be green/black on 74? There's 1 wire under battery box that's not going to the fuel pump and it's green/black. From my reading in Haynes manual that's correct |
arsprod temp gauge May 17 2015, 04:26 PM
type47
L... May 17 2015, 05:28 PM
arsprod Thank you! I was looking at that yesterday tho... May 17 2015, 05:33 PM
type47
http://www.peli... May 23 2015, 03:48 PM
arsprod
http://www.pel... May 23 2015, 06:13 PM
SKL1 Get a new sending unit for the taco plate and put ... May 23 2015, 09:25 PM
steuspeed
... I sent my gauge to North Hollywood Speedomet... May 24 2015, 01:08 AM
arsprod
Get a new sending unit for the taco plate and put... May 24 2015, 06:57 AM
arkitect
Get a new sending unit for the taco plate and put... May 24 2015, 08:24 AM
arsprod This the correct part? http://www.egauges.com/Prod... May 24 2015, 07:44 AM
Java2570
This the correct part? http://www.egauges.com/Pro... May 24 2015, 08:43 AM
bdstone914
[quote name='arsprod' post='2190641' date='May 24... May 24 2015, 12:08 PM
brant I am facing the same problem
is there anyway to te... May 24 2015, 10:07 AM
bdstone914 Measure the resistance from the center terminal to... May 24 2015, 12:03 PM
Java2570 This thread has a ton of good oil temp info: http:... May 24 2015, 02:56 PM
arsprod Hmm... maybe just replacing wire is the answer May 24 2015, 05:55 PM
SKL1 Here's a picture of the gauge panel before I p... May 24 2015, 06:36 PM
arsprod So I've confirmed a connection from sender to ... May 31 2015, 07:56 AM
forrestkhaag I recently went thru this issue with my newly rewo... May 31 2015, 08:54 AM
arsprod
I recently went thru this issue with my newly rew... May 31 2015, 09:00 AM
arsprod Back at this - I've ordered a sender finally b... Jun 14 2015, 03:21 PM
stugray + to +12VDC (dash power)
GND to chassis ground
Th... Jun 14 2015, 04:00 PM
arsprod
T... Jun 14 2015, 05:40 PM
stugray
Thank you - appears mine is missing a lead to gr... Jun 14 2015, 06:57 PM
arsprod
Thank you - appears mine is missing a lead to g... Jun 15 2015, 08:17 AM
arsprod Follow up with some potentially helpful info for f... Jun 22 2015, 10:15 AM
stugray
- the wire from the sender to my gauge was disco... Jun 22 2015, 12:48 PM
arsprod
- the wire from the sender to my gauge was disc... Jun 22 2015, 01:15 PM
stugray
Thanks, me too! Just noticed your signature -... Jun 22 2015, 04:04 PM
arsprod
Thanks, me too! Just noticed your signature ... Jun 22 2015, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:02 PM |
