| sportlicherFahrer |
Apr 6 2015, 06:15 PM
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
| iankarr |
May 25 2015, 09:17 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I have a P-III on my 65 mustang. Works great. The big diff between the II and the III is that with the III you don't need to install a ring over your dizzy shaft. It senses when the lobe spins around (by the change in magnetic field).
Anyway, my PIII works great. Not sure if it's compatible with the 914. If it is, keep in mind that it either works or it doesn't...it's not like points which give you some notice when they're worn or on their way out. When the pertronix dies, it'll happen in an instant and you'll be stranded. That's why many P users keep a spare set of points or a spare PIII in the trunk (myself included)! |
sportlicherFahrer Pertronix Ignitor III Apr 6 2015, 06:15 PM
76-914 :popcorn: Apr 6 2015, 09:38 PM
colingreene I personally have had problems with the parts they... Apr 7 2015, 11:00 AM
Java2570 I've heard of others using Ignitor II but I... Apr 7 2015, 12:20 PM
SLITS
I've heard of others using Ignitor II but I... Apr 7 2015, 12:48 PM
SKL1 Why would this be better than Permatune? I'v... Apr 7 2015, 12:45 PM
Dave_Darling Why would this be better than Permatune?
The Per... May 25 2015, 08:35 PM
sportlicherFahrer Part number 71847v. They run about $130 on S... Apr 7 2015, 01:01 PM
Java2570 I don't see the specific instructions for the ... Apr 7 2015, 01:27 PM
euro911 I've been running a -II on my 2056 for over 3 ... May 25 2015, 04:55 PM
boxsterfan Opinions on the Pertronix are like reviews on Amaz... May 25 2015, 05:23 PM
Jetsetsurfshop You guys that are using the Pertronix III, what co... Aug 10 2017, 04:48 PM
Perry Kiehl Jet, check the classifieds. I have a Pertronix SVD... Aug 10 2017, 06:20 PM
bandjoey II installed on otherwise stock (blue coil) motor.... Aug 10 2017, 07:13 PM
solex I just installed the III and cannot seem to get th... Aug 11 2019, 01:39 PM
porschetub
I just installed the III and cannot seem to get t... Aug 11 2019, 03:14 PM
bbrock According to the Pertronix III instructions, it is... Aug 11 2019, 03:45 PM
SteveL I have had a Pertronix in place of the points for ... Aug 11 2019, 03:53 PM
solex I checked everything even called Pertronix prior t... Aug 11 2019, 05:18 PM
Gatornapper My dizzy just went bad & I have MSD and see th... Dec 7 2019, 06:58 PM
solex Spoke with Carl from Pertronix.
(1) I'm on va... Aug 15 2019, 08:35 AM
sportlicherFahrer :wavebye: OP here. I ended up canning the Ignitor... Aug 16 2019, 07:12 PM
solex Got it running, after checking everything I had m... Aug 22 2019, 12:24 PM
Rand Pertronix worked great for me for 20+ years. Then ... Aug 22 2019, 02:29 PM
Al Meredith I've had problems with two pertronix units . I... Aug 22 2019, 02:43 PM
solex
I've had problems with two pertronix units . ... Aug 22 2019, 04:07 PM
solex I have given up.
I order there epoxy coil with 0.... Aug 31 2019, 04:45 PM
ndfrigi here is my experienced with pertronix, bought my ... Aug 31 2019, 05:22 PM
solex I have no doubt that Pertronix I & II works ba... Sep 2 2019, 04:13 PM
sportlicherFahrer The 009 and pertronix units will "work" ... Dec 7 2019, 07:13 PM
Gatornapper Jim -
PRICELESS information - thank you. You kno... Dec 7 2019, 07:53 PM
Gatornapper Hmmm.....just thinking - my '76 2.0 was runnin... Dec 7 2019, 08:33 PM
rbzymek I installed a Pertronix III ignitor, Flamethrower ... Dec 7 2019, 07:52 PM
Gatornapper Thanks for the info.........
I'd love the 123... Dec 7 2019, 07:57 PM
sportlicherFahrer I'm running with 40's on mine. Stock cam w... Dec 7 2019, 08:22 PM
Gatornapper Jim -
Totally got you on the vacuum lines being ... Dec 7 2019, 08:48 PM
sportlicherFahrer I honestly don't have any hard data on the dif... Dec 9 2019, 05:52 AM
Gatornapper Seems this should be so simple - but it's not.... Dec 9 2019, 08:20 AM
sportlicherFahrer I've also heard of folks using the 205AB from ... Dec 9 2019, 08:29 AM
sportlicherFahrer Checking out the pertronix website, it looks like ... Dec 9 2019, 09:10 AM
Gatornapper Asked Pertronix about this - it will not fit/work ... Dec 10 2019, 12:25 PM
Gatornapper Decision made. Ordered new 009 dizzy from AA and ... Dec 9 2019, 10:49 AM
ClayPerrine
Decision made. Ordered new 009 dizzy from AA and... Dec 10 2019, 07:17 AM
Gatornapper Clay -
Thanks. Car had an 009 in it when I got i... Dec 10 2019, 12:37 PM
Gatornapper Clay & Perry -
What is it about the advance c... Dec 10 2019, 02:50 PM
rbzymek Clay,
What is the best option for a 1.8L dizzy sho... Dec 10 2019, 07:46 AM
ClayPerrine
Clay,
What is the best option for a 1.8L dizzy sh... Dec 10 2019, 10:52 AM
IronHillRestorations 009 is a great distributor, for a generator engine Dec 10 2019, 07:56 AM
Gatornapper As you said, "The "009" mechanical ... Dec 12 2019, 09:11 PM
sportlicherFahrer Saw reviews on Amazon and Summit of guys running t... Dec 10 2019, 12:33 PM
Gatornapper Jim -
Very interesting - but the 009 is on the wa... Dec 10 2019, 12:52 PM
rhodyguy It will work. Just not optimized curve. Find TDC o... Dec 10 2019, 02:08 PM
Gatornapper Sitting on TDC right now........of course, no mark... Dec 10 2019, 03:13 PM
sportlicherFahrer Should be able to see the notch on the flywheel th... Dec 10 2019, 03:18 PM
Gatornapper Already did that. Used small mirror to see 27 deg... Dec 10 2019, 03:23 PM
Gatornapper Ok, seeing from this chart what may be the issue.
... Dec 10 2019, 03:22 PM
yeahmag It may have been mentioned, but the 009 has too mu... Dec 10 2019, 05:58 PM
Gatornapper Aaron -
Thank you.
Ok, guys. What are my altern... Dec 10 2019, 06:32 PM
Gatornapper Aaron -
The total advance is easily reduced by be... Dec 10 2019, 07:17 PM
Tdskip Great chart, helps to visualize the considerations... Dec 10 2019, 06:39 PM
Gatornapper TD -
No mud at all. I looked at these and seriou... Dec 10 2019, 06:53 PM
Tdskip
TD -
No mud at all. I looked at these and serio... Dec 11 2019, 09:14 AM
Gatornapper Wondering where I could get a Bosche 009 made in B... Dec 10 2019, 08:05 PM
Tdskip
Wondering where I could get a Bosche 009 made in ... Dec 11 2019, 08:34 AM
Gatornapper Have you used them? If so, what has been your exp... Dec 11 2019, 09:29 AM
Gatornapper Found the advance curve for the Pertronix D182504 ... Dec 10 2019, 09:04 PM
ClayPerrine If you are looking for a distributor that works we... Dec 11 2019, 02:28 PM
Gatornapper Clay -
Thank you! What distributor would tha... Dec 11 2019, 08:09 PM
ClayPerrine I don't know the part number, but you should b... Dec 11 2019, 09:54 PM
Gatornapper Clay -
Thanks. Talked to Pelican yesterday - the... Dec 12 2019, 07:39 AM
ClayPerrine
Clay -
Thanks. Talked to Pelican yesterday - th... Dec 12 2019, 08:22 AM
Gatornapper Clay -
Do you see the '74 1.8 dizzy on either... Dec 12 2019, 09:57 AM
IronHillRestorations I put a brand new Pertronix SVDA on a customer car... Dec 12 2019, 07:50 AM
Gatornapper Perry -
Yes - their track record does not look go... Dec 12 2019, 09:49 AM
Gatornapper Perry -
Word seems to be that you do NOT leave th... Dec 12 2019, 09:53 AM
Tdskip This thread is practically begging for a table tha... Dec 12 2019, 08:49 AM
Gatornapper Bulls-eye.
This thread is practically begging fo... Dec 12 2019, 09:49 AM
sportlicherFahrer The ignitor I is prone to failure with KOEO for ex... Dec 12 2019, 10:07 AM
Gatornapper Jim -
Good news - makes sense Pertronix would fi... Dec 12 2019, 05:15 PM
rbzymek So I have a and OE dizzy that came off of a 1.8L ,... Dec 12 2019, 04:27 PM
Gatornapper I'm guessing, but the chart here
https://www... Dec 12 2019, 05:14 PM
Gatornapper From the Pelican Parts forum post in 2001, the diz... Dec 12 2019, 09:17 PM
914werke The ignitor I is prone to failure with KOEO for ex... Dec 12 2019, 07:23 PM
Gatornapper Rich -
Sorry - I'm relatively new at this 914... Dec 13 2019, 08:50 AM
Gatornapper Best price yet - Dansk - says it's for '74... Dec 12 2019, 08:56 PM
Gatornapper VERY INTERESTING.
A Pelican Parts forum discussio... Dec 12 2019, 09:04 PM
rbzymek GN-
I copied the dizzy part wrong. The good one i... Dec 13 2019, 09:37 AM
Gatornapper Ray -
Thanks - I did have the correct number.
No... Dec 13 2019, 10:05 AM
rbzymek Go with WTB. That's where I found mine for ... Dec 13 2019, 10:13 AM
Tdskip Hold on here - so we are putting down for future r... Dec 13 2019, 10:31 AM
rbzymek So the 231 181 009 aka 022 905 205AA has a curve d... Dec 13 2019, 10:52 AM
Gatornapper I agree - research I have done confirms that......... Dec 13 2019, 10:58 AM
Gatornapper What I'd like to know is where does the 022 90... Dec 13 2019, 11:03 AM
rbzymek FYI....
Dec 13 2019, 11:47 AM
Gatornapper AH-HA!
It's a VW Part number!
The 0 ... Dec 13 2019, 11:55 AM
Gatornapper Wondering if at this point we shouldn't move t... Dec 13 2019, 12:28 PM
rbzymek GN,
That's the Bosch number 231 181 009. The V... Dec 13 2019, 02:38 PM
Gatornapper NOW it makes sense!
Thank you!
On the Pe... Dec 13 2019, 06:59 PM
rbzymek Here is a graph of the curve base on the Pelican t... Dec 13 2019, 02:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 12:34 PM |
