FS 16 steel lug bolts for 914 four bolt, 16 lug bolts for sale |
forrestkhaag |
May 24 2015, 06:44 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I have a bundle of 16 good used black painted bolts / asking 40.00USD or make offer / Shipped CONTUS
(IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
euro911 |
May 28 2015, 01:50 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
2.5 ~ 3 hours isn't acceptable. If neither 914 (1) can't do better than 20 ~ 25 mph, I'd suggest the following before beginning a trek of this nature:
1. Valve adjustment set to spec (2) 2. Set dwell angle to +/- 49° (2) (better yet, install a Pertronix (3) (or = unit) 3. Ignition timing set to spec (typically 27° BTDC @ 3k RPM) (2) 4. Fresh fuel (rated for your particular application) 5. Induction system checked and adjusted for optimum efficiency (2) 6. Tires inflated properly (don't forget to torque lug bolts or nuts as needed) (2) Performing these procedures should decrease the time element between point A and B considerably - however, YMMV (4) (1) 914 is a trademarked numbering sequence pertaining to a product of PORSCHE gHmB, subsidiary of Volkswagen gHmB, Germany (2) Specific information should be obtained from a reputable source. (3) Pertronix is a trademarked entity and only used in this case as a possible alternative ignition component for automotive use (as noted). (4) Absolutely NO guarantees (written or verbal) are implied, and the author will not be held liable for any failure(s) due to misconstrued interpretation(s) or improper action(s) of any procedure(s) listed, or failure of any component(s) mentioned. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:05 AM |
