> engine knock or rattle, search continues... FOUND IT!
malcolm2
post May 26 2015, 10:45 AM
Let me ask......
Has anyone had an Alternator that knocks?
I have been searching for a random knocking or rattle noise. I thought for sure it was internal, maybe a rod or piston. The sound is random tho. I figured an internal noise would be timed with rotation.
Also thought it was from the passenger side.
I spent lots of time under the car with a stethoscope this weekend and I would bet a nickel it is not internal. Seems to be the fan, fan housing, or alternator; 'cause with the scope on the fan housing or alt. I can really hear the random knock. On the block, anywhere, all I hear is a faint consistent click of valves thru the case.
The fan is torqued and aligned, the belt has proper tension and the alternator was rebuilt 7,000 miles ago prior to my first start. Not sure what all the rebuild included, but I will try to find out. Thinking bearings, maybe?
I have had one suggestion.... remove the fan belt and start the car and listen. Can't think of any problems with that. Are there any?
Any thoughts or comments very much welcomed.
Clark
914_teener
post Jun 5 2015, 10:36 AM
Do you think you can post a picture of the failure?
malcolm2
post Jun 5 2015, 02:46 PM
QUOTE(914_teener @ Jun 5 2015, 11:36 AM) *
I am at Todd's now. It's in the back. I hear them beatin on it. So i can't get a photo. They say i had the belt too tight. Messed up both bearings and the frame. He maybe right but i am almost positive i followed the proceedure to allow some play.
He was dumbfounded cause it has no fan. I showed him the boot and cover but i don't think he follows.
He said a fan on the alt would suck air. Does our set up suck or blow?
Nice guy tho. No charge. No future warranty tho. Oh well.
malcolm2   engine knock or rattle   May 26 2015, 10:45 AM
pilothyer   It would be perfectly safe to remove the belt from...   May 26 2015, 11:17 AM
Dave_Darling   I've had one or two things fall into the fan o...   May 26 2015, 11:35 AM
rhodyguy   i chased a loosening belt issue and a weird rattle...   May 26 2015, 12:56 PM
saigon71   Have you done anything with the heat flapper boxes...   May 26 2015, 01:16 PM
malcolm2   Have you done anything with the heat flapper boxe...   May 26 2015, 07:00 PM
rgalla9146   Check the belt itself. I had a mysterious noise...   May 27 2015, 06:23 AM
larryM   I have been searching for a random knocking or r...   May 30 2015, 10:26 PM
malcolm2   I guess I'll take what comes. This post got mo...   May 31 2015, 08:42 PM
yeahmag   Man... If that CHT is accurate on the "hot...   Jun 1 2015, 06:13 PM
era vulgaris   Man... If that CHT is accurate on the "hot...   Jun 1 2015, 06:30 PM
malcolm2   Man... If that CHT is accurate on the "hot...   Jun 2 2015, 07:37 AM
somd914   I have a little piston slap on my 2056 when it...   Jun 1 2015, 07:16 PM
The Cabinetmaker   Sounds like crankshaft walk to me.   Jun 2 2015, 04:42 AM
somd914   Sounds like crankshaft walk to me. This is a ne...   Jun 2 2015, 05:22 AM
malcolm2   I don't discount the suggestions, but wouldn...   Jun 2 2015, 07:27 AM
McMark   Not uncommon for the lower alternator pivot bolt t...   Jun 2 2015, 12:46 PM
euro911   I watched your videos. My wife's 1.7 had a sim...   Jun 2 2015, 02:06 PM
malcolm2   I watched your videos. My wife's 1.7 had a si...   Jun 2 2015, 08:47 PM
worn   I watched your videos. My wife's 1.7 had a s...   Jun 3 2015, 12:52 PM
euro911   Check with Mark (McMark) ... maybe the high-output...   Jun 2 2015, 10:38 PM
Mblizzard   I have seen this on several rebuilt alternators fo...   Jun 3 2015, 04:40 AM
malcolm2   Bad news it sucks to fix. I am getting that ...   Jun 3 2015, 07:23 AM
euro911   Hmmm ... I have some spare alternators laying arou...   Jun 3 2015, 07:25 AM
r_towle   I would bring it back the same rebuilder. An alter...   Jun 3 2015, 06:46 PM
malcolm2   Copy and paste for now: http://youtu.be/OGZvXqZzK...   Jun 4 2015, 06:22 PM
Mblizzard   Clark I have a couple on the shelf if you need to ...   Jun 4 2015, 07:11 PM
malcolm2   Clark I have a couple on the shelf if you need to...   Jun 5 2015, 09:21 AM
somd914   Thanks for posting your findings. Certainly bette...   Jun 5 2015, 09:27 AM
914_teener   Do you think you can post a picture of the failure...   Jun 5 2015, 10:36 AM
malcolm2   Do you think you can post a picture of the failur...   Jun 5 2015, 02:46 PM
Mblizzard   The air should flow from the impeller housing rubb...   Jun 5 2015, 02:49 PM
malcolm2   The air should flow from the impeller housing rub...   Jun 5 2015, 02:52 PM
malcolm2   Final video on this subject.... For now! Tha...   Jun 8 2015, 08:45 AM
euro911   I try to get someone to help top-side while I...   Jun 8 2015, 12:35 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:27 PM
