> Gear shift adjustment, left and right
Kent
post Dec 20 2008, 11:39 PM
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
Hine62
post Jun 8 2015, 01:11 PM
Where is the adjustment screw? I think R & 1st are way too close to the drivers seat. I'm thinking this will fix it.
hine62
Kent   Gear shift adjustment   Dec 20 2008, 11:39 PM
Racer Chris   With the trans in neutral, attach a bungee from th...   Dec 21 2008, 12:06 AM
jim_hoyland   With the trans in neutral, attach a bungee from t...   Feb 1 2014, 09:42 PM
Racer Chris   With the trans in neutral, attach a bungee from ...   Feb 2 2014, 08:33 AM
Bruce Hinds   With the trans in neutral, attach a bungee from t...   Aug 19 2025, 03:46 PM
Joe Ricard   Damn I have been screwing around with "one sp...   Dec 24 2008, 09:02 PM
cpavlenko   :shock1: :shock1: :shock1: that is so simple, I...   Mar 11 2014, 10:06 PM
Red72   A bit of a ressurection here, but I'm having s...   May 18 2015, 05:57 PM
tomrev   A bit of a ressurection here, but I'm having ...   May 18 2015, 06:44 PM
Red72   A bit of a ressurection here, but I'm having...   May 21 2015, 12:01 PM
stugray   Another trick I have learned (even if using Racer ...   May 21 2015, 12:21 PM
Red72   So I'm now back to a point where I have first ...   May 24 2015, 04:58 PM
Dr Evil   Nope. The 4-5, 2-3 throws on a properly adjusted b...   May 25 2015, 09:05 PM
Hine62   Where is the adjustment screw? I think R & 1st...   Jun 8 2015, 01:11 PM
stugray   Where is the adjustment screw? I think R & 1s...   Jun 8 2015, 05:06 PM
rgalla9146   Mark both pieces with a fine tip magic marker put...   Jun 8 2015, 06:37 PM
db9146   So mine is a tailshifter and I just finished repla...   Jun 8 2015, 08:42 PM
Dave_Darling   Sounds like you may need to adjust the lever over ...   Jun 8 2015, 08:58 PM
RobW   I use the put it wrong method, and then estimating...   Jun 9 2015, 07:43 AM
Racer Chris   I use the put it wrong method, and then estimatin...   Jun 9 2015, 08:48 AM
Dr Evil   Put in 2nd. Disconnect shifter at rod (side shift)...   Jun 9 2015, 07:42 PM
Bruce Hinds   Put in 2nd. Disconnect shifter at rod (side shift...   Aug 19 2025, 08:48 PM
jdahl   Need some help here, I've tried Dr. Evil and R...   Dec 3 2016, 10:47 AM
Racer Chris   ... and rotated spline by spline. ... The splin...   Dec 3 2016, 03:01 PM
SKL1   Get Chris' new front adjuster... just a satis...   Dec 3 2016, 12:30 PM
Keith914   Check that nothing is preventing full left to righ...   Dec 3 2016, 02:03 PM
Dave_Darling   Check that nothing is preventing full left to rig...   Aug 19 2025, 07:07 PM
porschetub   I continue to struggle with mine and think I'a...   Dec 3 2016, 02:54 PM
Jack Standz   There is an access hole towards the rear of the ca...   Aug 19 2025, 06:55 PM
Bruce Hinds   There is an access hole towards the rear of the c...   Aug 19 2025, 08:43 PM
- Lo-Fi Version Time is now: 11th November 2026 - 06:35 PM
