6-conversion: distributor access, I need Pictures so I can use the sawzall |
brant |
May 5 2003, 08:46 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
HI everyone,
I've seen plenty of pictures here and there in the past, but don't know where to look now. I need pictures of how others have cut this access "port".. for distributor service. I'm ready to cut, but wanted to see some examples. and no I can't just put an electromotive on... its not legal in class... ha...ha... thanks for anyones time and help brant |
J P Stein |
May 5 2003, 12:38 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I would prolly have made it a bit larger. I couldn't pull the alternator out thru this hole.
I use it for adjusting valves. I have the pulley marked for TDC of each cylinder. Twice around, and the valves are set. Also, setting the ignition timeing. Should the fan belt break, one would play hell getting access to it without the hole.....reinstalling the shims without it would be an excersize in frustation. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:50 PM |
