| saigon71 |
Jun 10 2015, 07:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
74 2.0 D-Jet. Car is in a fine state of tune. Verified fuel pressure at 30 PSI. Removed distributor, cleaned & lubed advance plates and tested vacuum canister. Verified TPS is set correctly. MPS tested fine. ORIGINAL fuel injection harness. I went around the engine bay today and re-seated all FI related connections. The injectors are in unknown condition - came with the car.
This is different than the bucking I used to experience. I intermittently have a cylinder drop off. It happens at all speeds, but is really noticeable at idle. I had it running for a while in my driveway tonight and the exhaust fumes spelled especially "gassy." When it's not missing, it runs fantastic and idles perfectly. I think I have a fuel injector going bad. Can they fail intermittently? Anyone else experience something like this? I figured I would just pull all four injectors, run the fuel pump and measure the fuel...but I'm not sure I could find the faulty one if it functions correctly during the test. Pretty boring video (IMG:style_emoticons/default/dry.gif) Engine starts running rough intermittently at :40 (engine bay sound) and 2:07 exhaust. https://www.youtube.com/watch?v=xQoMS-NeOag...eature=youtu.be Any advice is appreciated. |
| jim_hoyland |
Jun 11 2015, 06:09 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Connections /connectors at the injectors was a problem I encountered. Didn't find the defects until I removed the harness and did a continuity test on all the wires.
saigon71 Fuel Injector Going Bad? Jun 10 2015, 07:32 PM
Mblizzard I would suggest disconnecting the injectors one at... Jun 10 2015, 07:46 PM
mepstein If the injectors have never been cleaned, consider... Jun 10 2015, 08:07 PM
Cj Honeycutt
If the injectors have never been cleaned, conside... Jun 12 2015, 06:59 PM
Mark Henry The quick and dirty is to remove the wire one inje... Jun 11 2015, 05:30 AM
Philip W. i had a similar issue with my75 d-jet and thought ... Jun 11 2015, 06:45 AM
r_towle I have had the following.
Loose electrical connec... Jun 11 2015, 06:54 AM
r_towle duplicate Jun 11 2015, 06:54 AM
dlee6204
[quote name='mepstein' post='2197405' date='Jun 1... Jun 12 2015, 07:42 PM
[quote name='mepstein' post='2197405' date='Jun ... Jun 12 2015, 07:54 PM
kertwerks Group,
I've used the original bosch dizzy and... Jun 14 2015, 09:57 PM
saigon71 Thanks for the responses. The trigger points were... Jun 15 2015, 06:15 AM
mepstein Use a $6 usps priority box and you might have... Jun 15 2015, 06:40 AM
dlee6204 I've used Mr. Injector several times for a cou... Jun 15 2015, 07:45 AM
saigon71 I believe I have eliminated everything but the ECU... Jun 28 2015, 02:24 PM
BeatNavy Hey Bob - sorry to hear you're still chasing t... Jun 28 2015, 03:34 PM
mepstein I'll ship you the ecu and harness from my ... Jun 28 2015, 03:59 PM
saigon71
I'll ship you the ecu and harness from my ... Jun 28 2015, 09:18 PM
Ian Stott When you tested your fuel pressure and you said it... Jun 28 2015, 04:53 PM
BeatNavy
When you tested your fuel pressure and you said i... Jun 28 2015, 05:05 PM
saigon71
When you tested your fuel pressure and you said ... Jun 28 2015, 09:14 PM
914Mels Another possible problem would be the trigger poin... Jun 29 2015, 02:37 PM
saigon71 Well, the problem is fixed!
I filled up the... Jul 8 2015, 07:33 PM
Philip W.
I filled up th... Jul 8 2015, 07:59 PM
Jeff Bowlsby Great News Bob! Glad it worked out for you an... Jul 8 2015, 08:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:41 PM |
