> Fuel Injector Going Bad?, FIXED - Thanks 914 World!
saigon71
post Jun 10 2015, 07:32 PM
74 2.0 D-Jet. Car is in a fine state of tune. Verified fuel pressure at 30 PSI. Removed distributor, cleaned & lubed advance plates and tested vacuum canister. Verified TPS is set correctly. MPS tested fine. ORIGINAL fuel injection harness. I went around the engine bay today and re-seated all FI related connections. The injectors are in unknown condition - came with the car.
This is different than the bucking I used to experience. I intermittently have a cylinder drop off. It happens at all speeds, but is really noticeable at idle. I had it running for a while in my driveway tonight and the exhaust fumes spelled especially "gassy."
When it's not missing, it runs fantastic and idles perfectly.
I think I have a fuel injector going bad. Can they fail intermittently? Anyone else experience something like this?
I figured I would just pull all four injectors, run the fuel pump and measure the fuel...but I'm not sure I could find the faulty one if it functions correctly during the test.
Pretty boring video (IMG:style_emoticons/default/dry.gif) Engine starts running rough intermittently at :40 (engine bay sound) and 2:07 exhaust.
https://www.youtube.com/watch?v=xQoMS-NeOag...eature=youtu.be
Any advice is appreciated.
r_towle
post Jun 11 2015, 06:54 AM
Custom Member
I have had the following.
Loose electrical connector at injector...wiggle loose randomly, fixed with new boots
Old worn out FI trigger points, new trigger points
Fuel filter clogged, crap in tank.....full douche, two new inline filter.
All of those problems gave me your conditions...all are pretty cheap to fix...
Rich
saigon71   Fuel Injector Going Bad?   Jun 10 2015, 07:32 PM
Mblizzard   I would suggest disconnecting the injectors one at...   Jun 10 2015, 07:46 PM
mepstein   If the injectors have never been cleaned, consider...   Jun 10 2015, 08:07 PM
Cj Honeycutt   If the injectors have never been cleaned, conside...   Jun 12 2015, 06:59 PM
Mark Henry   The quick and dirty is to remove the wire one inje...   Jun 11 2015, 05:30 AM
jim_hoyland   Connections /connectors at the injectors was a pro...   Jun 11 2015, 06:09 AM
Philip W.   i had a similar issue with my75 d-jet and thought ...   Jun 11 2015, 06:45 AM
r_towle   I have had the following. Loose electrical connec...   Jun 11 2015, 06:54 AM
r_towle   duplicate   Jun 11 2015, 06:54 AM
dlee6204   [quote name='mepstein' post='2197405' date='Jun 1...   Jun 12 2015, 07:42 PM
mepstein   [quote name='mepstein' post='2197405' date='Jun ...   Jun 12 2015, 07:54 PM
kertwerks   Group, I've used the original bosch dizzy and...   Jun 14 2015, 09:57 PM
saigon71   Thanks for the responses. The trigger points were...   Jun 15 2015, 06:15 AM
mepstein   Use a $6 usps priority box and you might have...   Jun 15 2015, 06:40 AM
dlee6204   I've used Mr. Injector several times for a cou...   Jun 15 2015, 07:45 AM
saigon71   I believe I have eliminated everything but the ECU...   Jun 28 2015, 02:24 PM
BeatNavy   Hey Bob - sorry to hear you're still chasing t...   Jun 28 2015, 03:34 PM
mepstein   I'll ship you the ecu and harness from my ...   Jun 28 2015, 03:59 PM
saigon71   I'll ship you the ecu and harness from my ...   Jun 28 2015, 09:18 PM
Ian Stott   When you tested your fuel pressure and you said it...   Jun 28 2015, 04:53 PM
BeatNavy   When you tested your fuel pressure and you said i...   Jun 28 2015, 05:05 PM
saigon71   When you tested your fuel pressure and you said ...   Jun 28 2015, 09:14 PM
914Mels   Another possible problem would be the trigger poin...   Jun 29 2015, 02:37 PM
saigon71   Well, the problem is fixed! I filled up the...   Jul 8 2015, 07:33 PM
Philip W.   Well, the problem is fixed! I filled up th...   Jul 8 2015, 07:59 PM
Jeff Bowlsby   Great News Bob! Glad it worked out for you an...   Jul 8 2015, 08:44 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:40 PM
