| thieuster |
Jun 17 2015, 03:54 AM
Member ![]() ![]() Group: Members Posts: 447 Joined: 31-January 15 From: 275 mls NW from Stuttgart. Member No.: 18,384 Region Association: Europe |
After two more or less shorter runs last week and Monday evening, I took the car out for a longer trip. I started at 5:30AM and went for a 100 mile round trip to the north and back home again. Great trip! And the speed makes the car very quiet! (contradictio? no!) The noise of the engine is 'pulled' away from the cabin by the air flowing over the car. Something I'd never experienced before, driving British classics with a lumpy straight engine in front of your knees!
Overall, the car runs beautifully. Two small niggles though. (Well, what else can you expect from a car that's been stored for 17 yrs?). First, when revving the car, it pulls great. But at the steady coast of 2200 rpm, the car tends to 'shake' a little, as if it's running a little too lean. Throttle Position Sensor or... simply a little too lean? What can I expect. Second, the indicator relay. I was under the impression that it was located at the back of the fuse box, under the dash. But I couldn't find it there. So I turned on the ignition and used the column stalk to trace the sound of the relay... There it was, way up behind the dash, close to the back of the gauges. I couldn't reach it from the 'footwell position'. So, I'm wondering: would it be easier to remove the gauge cluster from the dash? Funny thing is, when I pull the hazard switch, the light inside the switch blinks and 'clicks', however, there's nothing to see on the dash: no green lights. I was under the impression that both (hazard and indicator) are linked! Or has that to do with the fact that my car is a Euro Spec car? What's your opnion / experience with the matters mentioned above? Menno |
| TheCabinetmaker |
Jun 17 2015, 06:18 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I agree totally. I never drive my car under 3Krpm. I had a car that I took care of and the owner told me he never let the car go over 3k. He rode in my car one day and freaked out when I pushed it to 4500. That is when i realized why my tune ups went south so quickly.
thieuster 100 mile trip Jun 17 2015, 03:54 AM
era vulgaris Are you saying that your rpm for extended cruising... Jun 17 2015, 06:03 AM
thieuster
Are you saying that your rpm for extended cruisin... Jun 17 2015, 06:10 AM
malcolm2
Are you saying that your rpm for extended cruisin... Jun 18 2015, 07:28 AM
scott_in_nh Above 2000 rpm when you completely let off the thr... Jun 17 2015, 07:16 AM
Philip W.
Above 2000 rpm when you completely let off the th... Jun 17 2015, 07:36 AM
McMark The hazard switch can cause all sorts of turn sign... Jun 17 2015, 08:52 AM
whitetwinturbo :) It's nice to see a picture of your sled....... Jun 17 2015, 08:58 AM
thieuster
:) It's nice to see a picture of your sled...... Jun 17 2015, 09:18 AM
McMark Since the paintwork looks good from a 20ft distanc... Jun 17 2015, 02:21 PM
Spoke You say the turnsignal dash indicators do not ligh... Jun 17 2015, 09:46 AM
AlanG
You say the turnsignal dash indicators do not lig... Jun 17 2015, 05:46 PM
Dave_Darling Double-check that left-rear tire. It looks like t... Jun 17 2015, 12:15 PM
thieuster
Double-check that left-rear tire. It looks like ... Jun 17 2015, 12:38 PM
Spoke Looks better with the hub caps unless you black ou... Jun 17 2015, 04:40 PM
ConeDodger Hubcaps! :agree: Jun 17 2015, 10:31 PM
era vulgaris Keep the hubcaps. The outlaw thing only looks goo... Jun 17 2015, 11:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 02:13 PM |
