> A/C Install, The quest for coolness begins
jPs
post Sep 9 2004, 11:17 AM
I know most of y'all take A/C out of your 914's but I'm hoping to add it and am wondering if anyone can give a little advice.
I just aquired an old underdash unit manufactured by Heatransfer out of San Antonio, TX. I've read that VPC and DPT made underdash unit and so this might be a little unique...I dunno. At any rate the underdash unit appears to have everything needed such as expansion valve, standard pcar looking blower motor, etc. From the unit runs a red line (12v hot), green (ground), and red (compressor relay). Bench test shows that everything appears to work correctly and I also have picked up the original York compressor and a relay of some sort with the unit but I've no clue how it's to be wired or what. Below is a picture of the connectors and the only info on the relay is 150-10 12V.
Forgive my ignorance here but first does anybody know what the relay pinning is or is it even really necessary to run a relay. From what I can figure I should be able to connect (red) compress relay line direct to the compressor and evaporator fan and I'm guessing the underdash unit would trigger the compressor and evaporator fan to kick in as needed....am I off base here or do I need a go-between relay some where in this picture?
I have access to R12 and evac machine on the cheap and so I may upgrade the compressor down the road based on performance but for right now I'd like to get it all hooked up and see how it runs to begin with.....any advice would be GREATLY appreciated. I am willing to buy a new relay but admittedly I'm clueless on what I would need.
jPs
post Sep 10 2004, 06:33 AM
My teener previously had air and the PO had left the condensor and lines in tact but everything else was missing. Here's the trunk area and you can see the cutout area done by the original install. There's some surface rust so I'll be cleaning and painting all this up. I'm also not real satisfied with the air circulation as you can see the cutout areas are kinda silly....I've a few ideas and will be rearranging the layout.
You'll also note the hardline coming up from the bottom and all lines will be replaced. On the top left of the picture you'll note the cutouts for the lines. One was used for the windshield wiper pressure hose to the spare tire and since I'm going to replace that with a electric pump driven system I'll probably make use of that for a/c line routing.
jPs   A/C Install   Sep 9 2004, 11:17 AM
MarkV   The manual has a wiring diagram that should help. ...   Sep 9 2004, 11:27 AM
PorscheTom   I'm no expert, but when I installed A/C in my ...   Sep 9 2004, 11:32 AM
jPs   Thanks for the info this cleared up the questions....   Sep 9 2004, 11:47 AM
3d914   jPs, Here's a link to a previous posting. It ...   Sep 9 2004, 01:15 PM
jPs   3D914, Thank you VERY much...going to get replace...   Sep 9 2004, 04:26 PM
Kerrys914   I have the DPD system in mine with a few tweeks an...   Sep 9 2004, 04:45 PM
Aaron Cox   a little off topic but.. i saw a street/strip bug...   Sep 9 2004, 04:49 PM
SpecialK   In the relay pic, typically the two terminals to t...   Sep 9 2004, 05:45 PM
MarkV
  Sep 9 2004, 06:35 PM
jPs   Looks like I've a finalized plan now, just nee...   Sep 9 2004, 07:14 PM
Hi_Fi_Guy   For those of us longing to get their A/C units upd...   Sep 9 2004, 07:33 PM
jr91472   Great thread jP, send us some pics. Would love to...   Sep 9 2004, 07:49 PM
Kerrys914   ACKITS.com is a great place to get parts. I'll...   Sep 10 2004, 05:58 AM
jPs   Sharing the project seems like a good idea and so ...   Sep 10 2004, 06:23 AM
jPs   Here's the original condensor mounting unit + ...   Sep 10 2004, 06:26 AM
jPs   My teener previously had air and the PO had left t...   Sep 10 2004, 06:33 AM
3d914   jPs, Before you cut up the hole(s) in the trunk a...   Sep 10 2004, 07:26 AM
maf914   jPs, The picture of the trunk reminds me that the...   Sep 10 2004, 07:32 AM
Kerrys914   Do you have the pulley that mounts behing the cool...   Sep 10 2004, 07:52 AM
jPs   The PO had the engine rebuilt and the pulley was m...   Sep 10 2004, 10:09 AM
maf914   If you wanted to keep the tow eye you probably cou...   Sep 10 2004, 10:57 AM
MarkV   My car came with a non operational VPC system ins...   Sep 10 2004, 12:35 PM
Kerrys914   The DPD system I have doesn't have the "scoop"...   Sep 10 2004, 01:27 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:15 PM
