jPs |
Newbie ![]() Group: Members Posts: 46 Joined: 17-August 04 From: Austin, Texas Member No.: 2,554 ![]() |
I know most of y'all take A/C out of your 914's but I'm hoping to add it and am wondering if anyone can give a little advice.
I just aquired an old underdash unit manufactured by Heatransfer out of San Antonio, TX. I've read that VPC and DPT made underdash unit and so this might be a little unique...I dunno. At any rate the underdash unit appears to have everything needed such as expansion valve, standard pcar looking blower motor, etc. From the unit runs a red line (12v hot), green (ground), and red (compressor relay). Bench test shows that everything appears to work correctly and I also have picked up the original York compressor and a relay of some sort with the unit but I've no clue how it's to be wired or what. Below is a picture of the connectors and the only info on the relay is 150-10 12V. Forgive my ignorance here but first does anybody know what the relay pinning is or is it even really necessary to run a relay. From what I can figure I should be able to connect (red) compress relay line direct to the compressor and evaporator fan and I'm guessing the underdash unit would trigger the compressor and evaporator fan to kick in as needed....am I off base here or do I need a go-between relay some where in this picture? I have access to R12 and evac machine on the cheap and so I may upgrade the compressor down the road based on performance but for right now I'd like to get it all hooked up and see how it runs to begin with.....any advice would be GREATLY appreciated. I am willing to buy a new relay but admittedly I'm clueless on what I would need. Attached image(s) ![]() |
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
Do you have the pulley that mounts behing the cooling fan?
If you are going to reuse the old hoses I would just connect up what you have for parts. I wouldn't buy anything new and connect it into the old system. Chances are high it will need to be opend back up next spring (IMG:style_emoticons/default/sad.gif) You will also probably loose your charge of R-12 over the winter since the old system was designed with bleed typoe hose. Once you get the $$ ready to do the system right and replace everything listed earlier with new. The cost of my A/C systems was about $150 for the original A/C system and about another $200 for the retro fit to R134a and new parts. Labor was all done by me (IMG:style_emoticons/default/smile.gif) that saved some big $$$$ A/C shops get a premium rate for labor. Cheers |
Lo-Fi Version | Time is now: 1st August 2025 - 04:11 PM |
