| lugnuts |
Jun 20 2015, 08:00 AM
Newbie ![]() Group: Members Posts: 1 Joined: 14-June 15 From: Wendell NC Member No.: 18,855 Region Association: South East States |
I'm a newbie so be patient.
I just purchased 74 2.0 and drove it home 100+ miles on 98 degree day. Temp gauge got in the 260-280 range but I "made it". Couple days after, I cranked the car to put it on the lift for a once over and prep for oil change. After cranking oil pressure reads 80+ and light is on. NO unusual noise. Idles ok Once I saw pressure was hanging out in the high zone and the light was on I immediately turned it off. What have I done? (IMG:style_emoticons/default/headbang.gif) What steps to analyze the issue? FYI, Once on lift I did find the wire from thermostat was not connected (Per reading, I believe it fails to desired flap position for cooling) Per PO receipt for most recent oil change using Castrol 20-50 @ 4.8 qts |
| rhodyguy |
Jun 20 2015, 08:33 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
essentially, 5 quarts is a lot of oil! recheck the oil level in the car while cold and static.
lugnuts Oil pressure jumped Jun 20 2015, 08:00 AM
Java2570 Oil change with filter replacement should get 3.7 ... Jun 20 2015, 08:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 03:28 PM |
