 Forum Rules Classified Rules!
> FS: (CA) '74 914 flat 6 Subaru project, Stalled EZ30D swap, and it's time to move on
thenewwazoo
post Jun 14 2015, 10:47 PM
Car was sold for $5k
Hello! This is me on my Honda RVF400R, a rare grey-market 400cc V4 motorcycle that I've been restoring over the last two years.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343692.1.jpg)
Why am I posting a picture of a motorcycle? In order to help explain why my project '74 914 is for sale. When I bought this car and began the project, I was living on the East coast, had a low-stress job, and hadn't get gotten hooked on motorcycles. Now I'm in California, where time is tight and space is limited. It's time to admit that I will never finish this to the high level of quality I demand of myself, and I need to hand this project off to someone who will be excited to finish it. Or sell it for parts. Buyer's choice.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343692.2.jpg)
If you'd like you can skip straight to the photo album.
The car is in Redwood City, CA.
Here's the Cliff's notes of what's modified:
1974 Porsche 914 with approximately 117,183 miles
2001 Subaru EZ30 (non-AVCS, single-port flat 6) in place and ready to go
Intake using Weber trumpets, Triumph Speed Triple 1050i throttle bodies, and custom 3D printed intake manifolds
Complete engine wiring harness built with re-pinned stock engine connectors, and mated with totally stock chassis harness - no stock wiring was cut!
Comes with a MegaSquirt that I'll convert to 6cyl operation for you
Subframe (over)built by Performance Fabrication of San Carlos, CA, who do championship-winning work
Coldwater Conversions half-shafts in installed axles
2006 Impreza RS transmission, converted to 2WD
MR2 cable shifter with custom mount
Honda clutch slave cylinder with braided SS clutch line mated to stock pedal cluster
Low mileage on PO-installed KYB struts, SS brake lines, new brake pads (you can see the ad from when I bought the car: http://www.914world.com/bbs2/index.php?sho...100557&hl=)
Custom-specified Griffen 3" thick radiator
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343693.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343693.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343694.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343694.6.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343695.7.jpg)
No 914 is rust-free, but this one has surprisingly little, and it was repaired with some kind of epoxy by a previous owner. It's been stored indoors in California, so there's no new rust since then. In 2009 George Hussey described it as "solid, but a basket case", which was perfect for me. The glass is all good, the chassis is good, the interior is good... the car was, and is, a perfect candidate for conversion. My entire goal was a stock 914 with a fun, modern waterpumper, and I based it on a sweet-driving car with a very tired engine.
I have intentionally cut as little as possible. Only two cuts have been made to the sheet metal: clearance for the engine (and access to the starter), and mounting for the clutch master/pedal. You'll need to cut the front for radiator ducting; I never did. The front trunk had a dealer-installed A/C system; I planned to use that hole for the radiator outlet. Other than that, the car is as stock as it can be. I especially didn't cut any wires. The engine wiring harness is entirely self-contained and replaces the stock relay board.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343696.8.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343696.9.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343697.10.jpg)
This one's hard to see - it's where the new wiring harness terminates in a 14-pin plug that connects right up to the stock chassis wiring. No cutting, no splicing.
There's still a fair bit to be done, of course, but the parts that are "scariest" to everyone else (the intake manifold, the wiring harness, and connecting the shifter to the wheels) are all finished. The car needs its cooling system built (I've got a plan you can follow, or go your own way), needs an exhaust (I'll provide flanges for the EZ30 side), and ECU tuning, along with a reasonable list of odds and ends which I will happily list and discuss with you. If finishing it were fast or easy, I'd have finished it to recoup costs. It's a project, but I think it's got real potential.
The car also includes a small assortment of stock parts that were either removed or spares, but most of what I removed was sold to local 914 owners.
Interested? Want more pictures? Want details? Want to ask more about my stupid motorcycle habit? Please get in touch. If I could get $5k for the entire bundle, I'd be quite happy, but please feel free to make offers. The car has languished for nearly two years now; I'd like to see it gone.
Car is sold.
Thanks,
Brandon
thenewwazoo
post Jun 20 2015, 04:37 PM
Oh! Also, a few things that I should add or clarify:
I have a folder of paperwork dating back to about 1994. It's probably not a complete record, but it's fun to look through.
I also have an owner's manual in ... poor condition. I'll throw that in if you'd like.
The transmission is actually from a 2005 Impreza RS, according to the receipt. I was confused because the car has a 2006-style clutch setup, with the "push" slave cylinder (earlier cars had a "pull" slave cylinder, which is bulkier). The car has a lightweight flywheel. It will probably sound very, very mean.
The tires are as low-miles as they look, and they've been stored indoors out of sunlight. That said, they're still 5-6 years old, and have been stationary for years and probably flat-spotted. I would expect to replace them before really using the car, but they hold air just fine.
Yes, the car could be put back to stock if you really wanted to. I don't know why you would, but some have asked.
thenewwazoo   FS: (CA) '74 914 flat 6 Subaru project   Jun 14 2015, 10:47 PM
matthepcat   Wow. Very unique....and along the lines i'm lo...   Jun 15 2015, 12:07 AM
LeftCoastErik   Matt, you should already be driving this car! ...   Jun 15 2015, 11:46 AM
matthepcat   Matt, you should already be driving this car...   Jun 15 2015, 03:30 PM
PotterPorsche   ez30 flat six is an impressive engine. I think 212...   Jun 15 2015, 05:52 PM
MadDog415   ez30 flat six is an impressive engine. I think 21...   Jul 26 2015, 08:40 PM
whitetwinturbo   :agree: Could be the one for the father / son proj...   Jun 15 2015, 08:17 PM
Andyrew   Thats pretty darn cheap... Anyone think it'll ...   Jun 15 2015, 08:32 PM
Chris H.   Thats pretty darn cheap... Anyone think it'll...   Jun 16 2015, 07:22 AM
JRust   Damn it if my daughter wasn't getting married ...   Jun 15 2015, 10:05 PM
thenewwazoo   Thanks, everyone, for the kind words. I tried to p...   Jun 15 2015, 11:17 PM
cbehr   If I didn't live across the county I'd be ...   Jun 16 2015, 06:20 AM
thenewwazoo   ... cool carb setup... Just to clarify, this car ...   Jun 16 2015, 08:45 AM
thenewwazoo   Hi everyone, it looks like I might have screwed up...   Jun 16 2015, 10:17 AM
jpnovak   I would buy it if I did not have to ship it. I mi...   Jun 17 2015, 04:17 PM
914forme   Love the intakes, I have the TBs sitting in the sh...   Jun 17 2015, 06:43 PM
JRust   This will piss my wife off but if I got to it befo...   Jun 17 2015, 08:28 PM
mepstein   looks like a great project.   Jun 18 2015, 05:15 AM
fs096b   sent email and pm, like to make an offer, check yo...   Jun 18 2015, 08:19 PM
matthepcat   Thought I would post some info on this car. I visi...   Jun 20 2015, 03:48 PM
thenewwazoo   Thanks for the kind words, Matt! It was a plea...   Jun 20 2015, 04:30 PM
thenewwazoo   Oh! Also, a few things that I should add or cl...   Jun 20 2015, 04:37 PM
JRust   Hey guys I held off as some of you are closer. I k...   Jun 21 2015, 02:34 PM
Mueller   Hey guys I held off as some of you are closer. I ...   Jun 21 2015, 03:08 PM
matthepcat   Haha. He is an hour away. :) Hey guys I held ...   Jun 21 2015, 08:25 PM
Mike Bellis   Love the look of the intake manifolds but what is ...   Jun 21 2015, 11:00 PM
thenewwazoo   Love the look of the intake manifolds but what is...   Jun 22 2015, 12:24 AM
jd74914   Love the look of the intake manifolds but what i...   Jul 7 2015, 03:30 PM
thenewwazoo   Car's still available. Someone come and give i...   Jun 30 2015, 06:04 PM
green914   :drooley:   Jul 21 2015, 05:42 PM
thenewwazoo   It's still around. There's been a steady s...   Jul 21 2015, 06:41 PM
green914   PM coming your way.   Jul 22 2015, 03:24 PM
bfrymire   I am really surprised this is still around! I...   Jul 22 2015, 05:23 PM
thenewwazoo   And it's gone! Thanks, everyone, for the k...   Aug 2 2015, 03:24 PM
matthepcat   Finally! Sorry it took so long Brandon. By ch...   Aug 2 2015, 08:32 PM
thenewwazoo   Finally! Sorry it took so long Brandon. By c...   Aug 2 2015, 08:55 PM
Chi-town   Does anyone know who bought this car or the drivet...   Sep 3 2018, 05:55 PM
MikeInMunich   Just saw this thread now. I’m personally baffled...   Sep 4 2018, 02:13 PM
matthepcat   3 year old thread bump... nice!   Sep 6 2018, 01:42 PM
Chi-town   3 year old thread bump... nice! Was hoping...   Sep 6 2018, 11:22 PM
thenewwazoo   I might know where to find him. I have to warn yo...   Sep 7 2018, 12:03 AM
Chi-town   I might know where to find him. I have to warn y...   Sep 8 2018, 08:14 AM
Chi-town   @thenewwazoo any luck?   Oct 4 2018, 08:59 AM
thenewwazoo   http://pornoscan.us/~bmatt/EZ30/   Oct 4 2018, 11:51 AM
Chi-town   You are the MAN!   Oct 4 2018, 12:25 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:56 AM
