914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,206 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
My plan for today was simple for today. I was going to install the short shifter. I knew that the clutch tube had been repaired because I could see it in the rear. After I got the console out is when the fun began. I pulled up the carpet and found 2 tunnel cuts. I peeked under the cuts and things looked good. I pulled the shifter and then found this mess. (IMG:style_emoticons/default/headbang.gif)
The weld had broken and looked rubbed. I flipped the shifter over and found that they had ground the shifter lever. This explained why the shifter was stiff in reverse and first. Now I will have to get the cutting wheel and burr grinder and cut center mess out. (IMG:style_emoticons/default/sawzall-smiley.gif) Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Take the cable out while welding the tube....sorry to say.
It's very thin metal, so brazing it may be better if you have a torch. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:51 PM |
