| last337 |
Jun 21 2015, 05:56 PM
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
First off this is a '73 model.
I have been going over the wiring diagram for harness plug going from relay board to starter. I pulled the plug apart and for some reason the #6 post (yellow) is cut going into loom and there is no slip connector inside the plug. Now I know I didnt remove that connector from inside the plug but I cant recall if that yellow wire going into the loom (that goes to 50 side of starter) was cut when the tin/starter/etc was all removed. I checked voltage for that post on the plug and get .45v with key in on position and only slightly higher .50v in start position. I dont have a current meter so I cant tell what the amps are at each key position. Looking at the actual post itself it appears someone at one time soldered to post #6 (see pic) but there is nothing there now. I really wish I could recall what it looked like before but that was 2 years ago and I dont even know if I was the one that pulled those connectors off. Is it possible that there is another post/spot that could have been used to fire the starter? What should I check to ensure that post #6 is doing what it should do when key is turned to 'start' position? I have been going all through the diagrams but just cant imagine how else the starter would engage. |
last337 I was just looking at options for starter and foun... Jun 21 2015, 06:10 PM
Shadowfax Not sure if the '73 model has it, but have you... Jun 21 2015, 07:00 PM
last337
Not sure if the '73 model has it, but have yo... Jun 21 2015, 07:16 PM
SLITS It prevents the car from starting unless the seat ... Jun 21 2015, 07:51 PM
last337
It prevents the car from starting unless the seat... Jun 21 2015, 07:55 PM
Shadowfax From Jeff Bowlsby's site: http://bowlsby.net/9... Jun 21 2015, 08:18 PM
last337
From Jeff Bowlsby's site: http://bowlsby.net/... Jun 21 2015, 08:41 PM
Shadowfax You may need to source a wiring harness. In the me... Jun 21 2015, 09:07 PM
Jeff Bowlsby Guys....OP said he has a 1973. 1973 cars don... Jun 21 2015, 09:21 PM
last337 Well I pulled the whole relay board today and when... Jun 22 2015, 04:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:51 PM |
