> Relay board to starter
last337
post Jun 21 2015, 05:56 PM
First off this is a '73 model.
I have been going over the wiring diagram for harness plug going from relay board to starter. I pulled the plug apart and for some reason the #6 post (yellow) is cut going into loom and there is no slip connector inside the plug. Now I know I didnt remove that connector from inside the plug but I cant recall if that yellow wire going into the loom (that goes to 50 side of starter) was cut when the tin/starter/etc was all removed. I checked voltage for that post on the plug and get .45v with key in on position and only slightly higher .50v in start position. I dont have a current meter so I cant tell what the amps are at each key position. Looking at the actual post itself it appears someone at one time soldered to post #6 (see pic) but there is nothing there now. I really wish I could recall what it looked like before but that was 2 years ago and I dont even know if I was the one that pulled those connectors off.
Is it possible that there is another post/spot that could have been used to fire the starter? What should I check to ensure that post #6 is doing what it should do when key is turned to 'start' position? I have been going all through the diagrams but just cant imagine how else the starter would engage.
SLITS
post Jun 21 2015, 07:51 PM
"This Utah shit is HARSH!"
It prevents the car from starting unless the seat belt is on.
Two big yellow/w red, as I remember, go to a relay setup under the passenger seat. To defeat the interlock, you remove the two big wires and join them together.
last337
post Jun 21 2015, 07:55 PM
QUOTE(SLITS @ Jun 21 2015, 08:51 PM) *
There isnt much of anything under the seats really. The interior has been pulled out more than once by PO's and now there is just rats nest of stuff with exception of wiring going through tunnel. Any pics of what Id be looking for?
- Lo-Fi Version Time is now: 7th December 2025 - 09:51 PM
