| thenewwazoo |
Jun 14 2015, 10:47 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California |
Car was sold for $5k
Hello! This is me on my Honda RVF400R, a rare grey-market 400cc V4 motorcycle that I've been restoring over the last two years. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343692.1.jpg) Why am I posting a picture of a motorcycle? In order to help explain why my project '74 914 is for sale. When I bought this car and began the project, I was living on the East coast, had a low-stress job, and hadn't get gotten hooked on motorcycles. Now I'm in California, where time is tight and space is limited. It's time to admit that I will never finish this to the high level of quality I demand of myself, and I need to hand this project off to someone who will be excited to finish it. Or sell it for parts. Buyer's choice. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343692.2.jpg) If you'd like you can skip straight to the photo album. The car is in Redwood City, CA. Here's the Cliff's notes of what's modified: 1974 Porsche 914 with approximately 117,183 miles 2001 Subaru EZ30 (non-AVCS, single-port flat 6) in place and ready to go Intake using Weber trumpets, Triumph Speed Triple 1050i throttle bodies, and custom 3D printed intake manifolds Complete engine wiring harness built with re-pinned stock engine connectors, and mated with totally stock chassis harness - no stock wiring was cut! Comes with a MegaSquirt that I'll convert to 6cyl operation for you Subframe (over)built by Performance Fabrication of San Carlos, CA, who do championship-winning work Coldwater Conversions half-shafts in installed axles 2006 Impreza RS transmission, converted to 2WD MR2 cable shifter with custom mount Honda clutch slave cylinder with braided SS clutch line mated to stock pedal cluster Low mileage on PO-installed KYB struts, SS brake lines, new brake pads (you can see the ad from when I bought the car: http://www.914world.com/bbs2/index.php?sho...100557&hl=) Custom-specified Griffen 3" thick radiator (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343693.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343693.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343694.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343694.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343695.7.jpg) No 914 is rust-free, but this one has surprisingly little, and it was repaired with some kind of epoxy by a previous owner. It's been stored indoors in California, so there's no new rust since then. In 2009 George Hussey described it as "solid, but a basket case", which was perfect for me. The glass is all good, the chassis is good, the interior is good... the car was, and is, a perfect candidate for conversion. My entire goal was a stock 914 with a fun, modern waterpumper, and I based it on a sweet-driving car with a very tired engine. I have intentionally cut as little as possible. Only two cuts have been made to the sheet metal: clearance for the engine (and access to the starter), and mounting for the clutch master/pedal. You'll need to cut the front for radiator ducting; I never did. The front trunk had a dealer-installed A/C system; I planned to use that hole for the radiator outlet. Other than that, the car is as stock as it can be. I especially didn't cut any wires. The engine wiring harness is entirely self-contained and replaces the stock relay board. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343696.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-10883-1434343696.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-10883-1434343697.10.jpg) This one's hard to see - it's where the new wiring harness terminates in a 14-pin plug that connects right up to the stock chassis wiring. No cutting, no splicing. There's still a fair bit to be done, of course, but the parts that are "scariest" to everyone else (the intake manifold, the wiring harness, and connecting the shifter to the wheels) are all finished. The car needs its cooling system built (I've got a plan you can follow, or go your own way), needs an exhaust (I'll provide flanges for the EZ30 side), and ECU tuning, along with a reasonable list of odds and ends which I will happily list and discuss with you. If finishing it were fast or easy, I'd have finished it to recoup costs. It's a project, but I think it's got real potential. The car also includes a small assortment of stock parts that were either removed or spares, but most of what I removed was sold to local 914 owners. Interested? Want more pictures? Want details? Want to ask more about my stupid motorcycle habit? Please get in touch. If I could get $5k for the entire bundle, I'd be quite happy, but please feel free to make offers. The car has languished for nearly two years now; I'd like to see it gone. Car is sold. Thanks, Brandon |
| JRust |
Jun 21 2015, 02:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Hey guys I held off as some of you are closer. I know a few were going to check it out. I wanted Brandon to have a shot of getting out from under it sooner rather than later. I've got a crazy couple weeks ahead & no time to get down there. If none of you pick it up I will eventually. It will be an extra car for me. So while I would like it. I would rather see it go to someone it will be a priority for. I will put it to use eventually if one of you don't soon (IMG:style_emoticons/default/evilgrin.gif)
| Mueller |
Jun 21 2015, 03:08 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Hey guys I held off as some of you are closer. I know a few were going to check it out. I wanted Brandon to have a shot of getting out from under it sooner rather than later. I've got a crazy couple weeks ahead & no time to get down there. If none of you pick it up I will eventually. It will be an extra car for me. So while I would like it. I would rather see it go to someone it will be a priority for. I will put it to use eventually if one of you don't soon (IMG:style_emoticons/default/evilgrin.gif) Seems like a great deal...way too $$ for me, besides one non-running 914 is enough for me, I wish he was closer so I could at least check it out! |
| matthepcat |
Jun 21 2015, 08:25 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Haha. He is an hour away. (IMG:style_emoticons/default/smile.gif)
thenewwazoo FS: (CA) '74 914 flat 6 Subaru project Jun 14 2015, 10:47 PM
matthepcat Wow. Very unique....and along the lines i'm lo... Jun 15 2015, 12:07 AM
LeftCoastErik Matt, you should already be driving this car! ... Jun 15 2015, 11:46 AM
matthepcat
Matt, you should already be driving this car... Jun 15 2015, 03:30 PM
PotterPorsche ez30 flat six is an impressive engine. I think 212... Jun 15 2015, 05:52 PM
MadDog415
ez30 flat six is an impressive engine. I think 21... Jul 26 2015, 08:40 PM
whitetwinturbo :agree: Could be the one for the father / son proj... Jun 15 2015, 08:17 PM
Andyrew Thats pretty darn cheap... Anyone think it'll ... Jun 15 2015, 08:32 PM
Chris H.
Thats pretty darn cheap... Anyone think it'll... Jun 16 2015, 07:22 AM
JRust Damn it if my daughter wasn't getting married ... Jun 15 2015, 10:05 PM
thenewwazoo Thanks, everyone, for the kind words. I tried to p... Jun 15 2015, 11:17 PM
cbehr If I didn't live across the county I'd be ... Jun 16 2015, 06:20 AM
thenewwazoo ... cool carb setup...
Just to clarify, this car ... Jun 16 2015, 08:45 AM
thenewwazoo Hi everyone, it looks like I might have screwed up... Jun 16 2015, 10:17 AM
jpnovak I would buy it if I did not have to ship it. I mi... Jun 17 2015, 04:17 PM
914forme Love the intakes, I have the TBs sitting in the sh... Jun 17 2015, 06:43 PM
JRust This will piss my wife off but if I got to it befo... Jun 17 2015, 08:28 PM
mepstein looks like a great project. Jun 18 2015, 05:15 AM
fs096b sent email and pm, like to make an offer, check yo... Jun 18 2015, 08:19 PM
matthepcat Thought I would post some info on this car. I visi... Jun 20 2015, 03:48 PM
thenewwazoo Thanks for the kind words, Matt! It was a plea... Jun 20 2015, 04:30 PM
thenewwazoo Oh! Also, a few things that I should add or cl... Jun 20 2015, 04:37 PM
Mike Bellis Love the look of the intake manifolds but what is ... Jun 21 2015, 11:00 PM
thenewwazoo
Love the look of the intake manifolds but what is... Jun 22 2015, 12:24 AM
jd74914
Love the look of the intake manifolds but what i... Jul 7 2015, 03:30 PM
thenewwazoo Car's still available. Someone come and give i... Jun 30 2015, 06:04 PM
green914 :drooley: Jul 21 2015, 05:42 PM
thenewwazoo It's still around. There's been a steady s... Jul 21 2015, 06:41 PM
green914 PM coming your way. Jul 22 2015, 03:24 PM
bfrymire I am really surprised this is still around! I... Jul 22 2015, 05:23 PM
thenewwazoo And it's gone! Thanks, everyone, for the k... Aug 2 2015, 03:24 PM
matthepcat Finally! Sorry it took so long Brandon.
By ch... Aug 2 2015, 08:32 PM
thenewwazoo
By c... Aug 2 2015, 08:55 PM
Chi-town Does anyone know who bought this car or the drivet... Sep 3 2018, 05:55 PM
MikeInMunich Just saw this thread now. I’m personally baffled... Sep 4 2018, 02:13 PM
matthepcat 3 year old thread bump... nice! Sep 6 2018, 01:42 PM
Chi-town
Was hoping... Sep 6 2018, 11:22 PM
thenewwazoo I might know where to find him.
I have to warn yo... Sep 7 2018, 12:03 AM
Chi-town
I have to warn y... Sep 8 2018, 08:14 AM
Chi-town @thenewwazoo any luck? Oct 4 2018, 08:59 AM
thenewwazoo http://pornoscan.us/~bmatt/EZ30/ Oct 4 2018, 11:51 AM
Chi-town You are the MAN! Oct 4 2018, 12:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:51 AM |
