Thursday, 14 August 2025
> 2056 cut out at 5500- 6000 rpm
jmargush
post Jun 22 2015, 08:33 AM
Second season on my 2056 with 9590 Raby cam and heads done by Len Hoffman. Stock L-jet injection.
When I run the car up to 5500-6000 rpm it cuts out like there is a revlimiter (which there isn't) or the valves are floating.
Could this be an issue of the L-jet injectors not supplying enough fuel at those conditions?
stugray
post Jun 22 2015, 08:45 AM
Do you have dual valve springs?
If not my car cuts out before 6k (due to valve float) with single springs.
But you can hear it coming on and it cuts out gradually.
If you have an adrupt cut out, it sounds electrical.
Is all of your ignition stock? Points or pertronix?
If points, have you replaced them (with the condensor) recently?
New coil or original?
- Lo-Fi Version Time is now: 14th August 2025 - 12:05 PM
