Brake master cylinder woes |
jmargush |
Jun 22 2015, 08:30 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I put a new 19mm master cylinder from PMB on my car within the last two years.
The pedal had been getting a little more travel in it over the past week or two. Yesterday at the Autox the pedal got enough travel that it tripped the warning light on. Does this point to a failed master cylinder? If I pump the pedal it will build pressure and reduce travel. after this is done it doesn't seem to drift to the floor with continued pressure. I bought from PMB because I learned form Eric that the ones you by at FLAPS don't have the correct material in the seals and that a new one should last years. |
Dave_Darling |
Jun 22 2015, 08:56 AM
It means you have air getting into your system. Could be from the master cylinder, could be from the calipers, could be from the lines. Time to start going over the system carefully, looking for leaks.
--DD |
Lo-Fi Version | Time is now: 10th June 2024 - 12:21 PM |
