> 2056 cut out at 5500- 6000 rpm
jmargush
post Jun 22 2015, 08:33 AM
Second season on my 2056 with 9590 Raby cam and heads done by Len Hoffman. Stock L-jet injection.
When I run the car up to 5500-6000 rpm it cuts out like there is a revlimiter (which there isn't) or the valves are floating.
Could this be an issue of the L-jet injectors not supplying enough fuel at those conditions?
stugray
post Jun 22 2015, 07:12 PM
It could be your coil or basically any part of the electrical system going bad.
I have seen more distributor/rotor/cap problems than one would think.
There's the usual list of culprits that most racers carry as spares (and diagnostic tools):
New rotor(s)
New Cap
New plug wires
Timing light w/ tach (can put it on each plug wire 1 at a time)
spare pertronix
spare points (to rule out bad pertronix)
Coils are usually last on that list, but most have replaced the stock coil with a Bosch Blue or equivalent
Even down to a spare distributor.
If the bearings are going bad they will run inconsistently at high RPM.
Is there ANY side to side wiggle in the rotor shaft?
- Lo-Fi Version Time is now: 12th July 2025 - 11:58 PM
