| bradtho |
Aug 22 2011, 11:18 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I'm thinking about taking my stock 1.7 to a 1911. Some old threads seem to suggest that you can't do this with the 1.7l heads, while others seem to suggest it's fine. Can anybody set me straight on if I would need new heads, if they'd need to be machined, or if I'm good to go?
Also, I've got 2 engines all with original german cylinders. Am I better off taking the best 4 and boring them out or going with new chinese cylinders (local shop recommends QSC). I've been thinking if I've got 4 decent ones that the OE cylinders would likely be better than the chinese stuff. anything else I should be thinking about? |
| jmill |
Aug 27 2011, 02:18 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
That's it!! (IMG:style_emoticons/default/piratenanner.gif) Thanks for the link. Below is some cut and paste info from the other site. -7.7:1 -RAT 9550 -1.7"Q" heads opened to 105mm register size (2.0) with 42X36 valves and no port work, by HAM. -Relocated spark plugs -stock crank and rods -RAT 96mm KB pistons and cylinders -RAT oil pump -36mm Weber carbs -Mallory Unilite dizzy It is imperative that you verify the current chamber volume and set CR accordingly with the tightest deck possible, optimum is .040 The 9550 also works well with very small carbs, like the Weber 36s. This is especially true with very high velocity ports and limited displacement. This is a D Jet compatible Combo. The 1.7 head works great for this combo due to the insane port velocity it offers and that port veocity is more imprtant than gross flow on this combo. |
| LukeD |
Jun 25 2015, 10:23 PM
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
That's it!! (IMG:style_emoticons/default/piratenanner.gif) Thanks for the link. Below is some cut and paste info from the other site. -7.7:1 -RAT 9550 -1.7"Q" heads opened to 105mm register size (2.0) with 42X36 valves and no port work, by HAM. -Relocated spark plugs -stock crank and rods -RAT 96mm KB pistons and cylinders -RAT oil pump -36mm Weber carbs -Mallory Unilite dizzy This is a D Jet compatible Combo. Will my 1.7 liter D-jet setup work with a build like this or will it require modification? |
bradtho building a 1911 from a 1.7 Aug 22 2011, 11:18 PM
Jake Raby Yes you can do this with the existing heads if you... Aug 23 2011, 12:10 AM
Valy
Jake,
Nice write-out but you better fix the ... Aug 23 2011, 03:02 PM
Vacca Rabite My 2056 uses 1.7 heads. It can be done.
That said... Aug 23 2011, 07:01 AM
HAM Inc What sort of performance are expecting from your 1... Aug 23 2011, 07:48 AM
bradtho
What sort of performance are expecting from your ... Aug 23 2011, 08:58 AM
69telecaster 35 years ago I bought a set of 96mm cylinders/pist... Aug 23 2011, 08:39 AM
HAM Inc 1.7's will work fine, but you'll need to h... Aug 23 2011, 10:49 AM
Jake Raby I didn't post it to sell stuff :-)
The majorit... Aug 23 2011, 03:20 PM
jmill Jake, I seem to recall you posting a dyno sheet an... Aug 23 2011, 04:41 PM
TargaToy Yes, Jake. Can you please post the 1911 stats bef... Aug 23 2011, 07:46 PM
TargaToy :bump: Aug 26 2011, 05:59 PM
jmill Found it. http://www.914world.com/bbs2/index.php?... Aug 26 2011, 06:31 PM
7275914911
Found it. [url=http://www.914world.com/bbs2/inde... Aug 27 2011, 10:00 AM
pete-stevers Funny thing i was thinking along the same lines...... Aug 26 2011, 07:54 PM
pete-stevers I would love to see how much juice could be made f... Aug 26 2011, 07:55 PM
HAM Inc How about a 90.5 x 78.4=2017cc's. Use the 1.7 ... Aug 27 2011, 09:41 AM
r_towle
How about a 90.5 x 78.4=2017cc's. Use the 1.7... Aug 27 2011, 01:50 PM
TargaToy THANK YOU for finding and posting the link. This ... Aug 27 2011, 12:36 PM
HAM Inc
The nice thing about the long stroke-small bore ... Aug 27 2011, 02:29 PM
pete-stevers What type of carbs did you run in that set up? Aug 27 2011, 03:22 PM
bam914 My dad has a 1911 in his 914. Len did the heads. ... Aug 27 2011, 03:27 PM
ripper911
My dad has a 1911 in his 914. Len did the heads.... Aug 28 2011, 05:38 PM
HAM Inc
I don't remember what it ended up with. Once... Aug 27 2011, 09:09 PM
bradtho OK, so Ham says no-go on boring my OE 1.7 cylinder... Aug 27 2011, 11:40 PM
HAM Inc I'm not going to comment on the Chinese cylind... Aug 28 2011, 07:59 AM
lonewolfe
I'm not going to comment on the Chinese cylin... Aug 3 2015, 01:50 AM
914_teener
I'm not going to comment on the Chinese cyli... Aug 3 2015, 09:48 AM
Dave_Darling There were 96es that fit 1.7 heads. They were ver... Aug 28 2011, 06:21 PM
rhodyguy interesting what you can find with a tablet. jake... Jun 25 2015, 06:12 PM
Dave_Darling It'll require some tweaking of the MPS, and po... Jun 26 2015, 08:49 AM
MikeInMunich
It'll require some tweaking of the MPS, and p... Apr 12 2020, 12:34 AM
lonewolfe Who makes and sells the 90.5 stroker pistons? Aug 3 2015, 10:35 AM
rhodyguy read jakes take on the 1.8 heads. in most cases th... Aug 3 2015, 10:37 AM
914werke Resurrection:
No one appeared to answer the questi... Nov 2 2017, 02:18 PM
Dave_Darling Check with AA Pistons. The 90.5 were a stock repl... Nov 2 2017, 05:28 PM
914_teener Wow....it is hard to believe that was two years ag... Nov 2 2017, 07:09 PM
Montreal914 About 30 years ago :rolleyes: I had a 1776cc type... Nov 2 2017, 08:14 PM
914werke
About 30 years ago :rolleyes: I had a 1776cc typ... Nov 2 2017, 08:51 PM
Montreal914
About 30 years ago :rolleyes: I had a 1776cc ty... Nov 2 2017, 09:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 05:46 PM |
