worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,488 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I finished making connections between '72 914 and '84? 911 3.2 using weather sealed Deutsch connectors from JEGs in place of the 14 pin plug for which I had no corresponding make plugs at either end.
One thing that puzzled me was a sender switch on the plate for venting the case on the engine. After a lot of poking around this would have stayed in the on position if the engine were hot,turning on the heater fan, forcing air through the shroud and the heat exchagers. It is labeled as engine compartment fan, but it also delivers the heat on those crisp days in the Alps. Once I figured that one out, I realized it could be used to instead operate the fans for my remote oil cooler mounted under trunk, ala the immortal build thread for Mike Wills. So, I know this did not show up in many model years, but has anyone done it, and more important, does it work. Apparently the switch drives a relay that turns the fan on when the oil warms up to drive the fan. I have a relay, and a fan, and by God I hope to warm the oil this year! Please help if you know what I am talking about, or even if you don't. |
screenguy914 |
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California ![]() |
I finished making connections between '72 914 and '84? 911 3.2 using weather sealed Deutsch connectors from JEGs in place of the 14 pin plug for which I had no corresponding make plugs at either end. One thing that puzzled me was a sender switch on the plate for venting the case on the engine. After a lot of poking around this would have stayed in the on position if the engine were hot,turning on the heater fan, forcing air through the shroud and the heat exchagers. It is labeled as engine compartment fan, but it also delivers the heat on those crisp days in the Alps. Once I figured that one out, I realized it could be used to instead operate the fans for my remote oil cooler mounted under trunk, ala the immortal build thread for Mike Wills. So, I know this did not show up in many model years, but has anyone done it, and more important, does it work. Apparently the switch drives a relay that turns the fan on when the oil warms up to drive the fan. I have a relay, and a fan, and by God I hope to warm the oil this year! Please help if you know what I am talking about, or even if you don't. Not aware of it on US 3.2s. However, you might consider using a manual ON-OFF switch to control the remote cooler fan and relay. Then you can control and confirm its operation as you see fit. Sherwood |
Lo-Fi Version | Time is now: 3rd July 2025 - 06:28 AM |
