> To those with 3.2s, Can I use the engine compartment fan switch
worn
post Jun 28 2015, 07:51 PM
I finished making connections between '72 914 and '84? 911 3.2 using weather sealed Deutsch connectors from JEGs in place of the 14 pin plug for which I had no corresponding make plugs at either end.
One thing that puzzled me was a sender switch on the plate for venting the case on the engine. After a lot of poking around this would have stayed in the on position if the engine were hot,turning on the heater fan, forcing air through the shroud and the heat exchagers. It is labeled as engine compartment fan, but it also delivers the heat on those crisp days in the Alps.
Once I figured that one out, I realized it could be used to instead operate the fans for my remote oil cooler mounted under trunk, ala the immortal build thread for Mike Wills. So, I know this did not show up in many model years, but has anyone done it, and more important, does it work. Apparently the switch drives a relay that turns the fan on when the oil warms up to drive the fan. I have a relay, and a fan, and by God I hope to warm the oil this year!
Please help if you know what I am talking about, or even if you don't.
GeorgeRud
post Jun 29 2015, 06:57 AM
I can't see any downside to having it control a relay to turn on an oil cooler fan. The 3.2s can get hot (as we found out at the French Lick Parade when sitting in traffic just idling). It would probably be nice to have a dash mounted switch as well since it's better to keep the oil cool than try to cool it back down when it's too hot.
- Lo-Fi Version Time is now: 2nd July 2025 - 11:15 PM
