SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
ChrisFoley |
Jun 30 2015, 12:01 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The bar which that covers the fill plug is part of a custom bracket to mount the -6 throttle linkage bellcrank on a non 914-6 transaxle.
john77 |
Jun 30 2015, 12:35 PM
Thanks guys.
The bar which that covers the fill plug is part of a custom bracket to mount the -6 throttle linkage bellcrank on a non 914-6 transaxle. Chris, have you dealt with one before? Looking at it it doesn't look like that big a job to remove it so I can change the tranny oil, just undo a few nuts and pull the throttle linkage to one side. |
Kansas 914 |
Jun 30 2015, 02:38 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Chris, have you dealt with one before? Looking at it it doesn't look like that big a job to remove it so I can change the tranny oil, just undo a few nuts and pull the throttle linkage to one side. While you have that "bar" off - notch it so you can get to the top plug next time. |
Bob L. |
Jun 30 2015, 03:37 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Chris, have you dealt with one before? Looking at it it doesn't look like that big a job to remove it so I can change the tranny oil, just undo a few nuts and pull the throttle linkage to one side. While you have that "bar" off - notch it so you can get to the top plug next time. If you don't have a -6 , you could probably just take it off and leave it off. It's just weight. |
ChrisFoley |
Jun 30 2015, 03:55 PM
Lo-Fi Version | Time is now: 28th May 2024 - 08:22 PM |
