Rear Brakes for the race car |
stugray |
Jun 28 2015, 12:51 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I posted this in the paddock, but didnt get much traffic over there.
I have three calipers ready to put back together on my bench and I am waiting to make the decision based on this question below. Anyone here ever modified their calipers by breaking out the knock back pins? As usual Eric's site has the most information regarding these pins, but he doesnt go into detail about the possible benefits of doing so. I was hoping to hear from at least one other racer that has done this, why, and what were the results? And.... just to confirm: it is the late front calipers that fit the rears , correct? (I have measured, but not test fit them yet) Based on some advice from other racers, I am installing some front calipers on the rear of the race car. Currently I have stock front calipers, stock rears, and a 19mm MC, and still have the stock rear prop valve. I have a few sets of late front calipers that I disassembled to rebuild for this change. One of the calipers had the pins for the knock back mechanism broken out by some previous owner. I understand that the newer A-calipers do not have this mechanism from the factory. How many others here have done the front caliper installation on the rear? Did you keep the rear prop valve, or go for an aftermarket like the tiltons? Has anyone heard of breaking out the knock back pin? If so, what advantage is this supposed to provide? Should I use calipers with the knock back system intact, or should I break the pins out of another caliper so I have a matched set? I plan on running KFP Gold pads on the front and Porterfield AP31T R4-S pads on the rear for some front bias. Any more tips or tricks ? |
brant |
Jun 29 2015, 10:06 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You need to use the early offset calipers. There is a difference Btwn early/late.
I can't fully remember but perhaps a spacer on the mounting points can allow the lares to work. |
stugray |
Jun 30 2015, 06:29 PM
You need to use the early offset calipers. There is a difference Btwn early/late. I can't fully remember but perhaps a spacer on the mounting points can allow the lares to work. Brant thanks! Your comment made me check again. I had selected the calipers with the correct offset from my pile. I just had not labeled them correctly as late vs early. So Early front calipers fit on the rear. (IMG:style_emoticons/default/agree.gif) Time to order a few more rebuild kits from Eric (IMG:style_emoticons/default/biggrin.gif) Of course Murphy's law - when I rebuilt a pair to put on the front, I chose late calipers at random (and then got the correct rotors to match). If I had picked Early, then now I would have the same type all the way around. Now I'll keep two spares, one early & one late. At least I have one of each with dual bleeders so theyll fit on either side. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:45 PM |
