| JoeDees |
Jun 30 2015, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I've concluded that I need to replace significant portions of the lower wheelhouse, inner long, and the suspension console. I've spent the day researching and reading the classic threads and like many of the rack-like assemblies my predecessors have built. Let's hear some easy but still effective ways to get this thing off the ground and straight enough for structural repairs.
I really like the one for "Bringing out your Dead" but can't quite figure out the points it's mounted. After bracing the doors, can I use the front jack points, a long support along the floors, the outer suspension console, and the trans mount area? I ready for some ideas. I'm trying to develop as many COAs (Courses of Action) as possible. Thanks. |
| infraredcalvin |
Jul 1 2015, 11:30 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,755 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
The 1.5 feet extra in front and back (if I understand correctly) should work, barely. You can build the rotisserie so it mounts closer to the car. I made this with no prior welding experience. I bought "the welders handbook" and my wife got me a 220v mig welder from Eastwood one Christmas. I went to a metal supply with the parts list from:
http://www.blueskymotorsports.com/index.ph...18&Itemid=6 I had to make a few adjustments based on material availability, but after about $300 in steel and an afternoons work cutting and welding I have this: You're going to have to learn/practice welding anyway, thick material is the place to start. I have a 2nd 914 tub to work on now, I was thinking of building a dolly so I have one of each. One thing to think about is how you're going to get it up in the rotisserie. I have a lift, so I have no need for attachments to raise or lower the car. I work on my cars alone so everything I do must be accomplished with one set of hands, a pain something's, but it is my retreat/my alone time. |
| stugray |
Jul 2 2015, 08:35 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I had to make a few adjustments based on material availability, but after about $300 in steel and an afternoons work cutting and welding I have this: One comment: DO NOT leave that stand with the center horizontal support out! (the one that connects the two stands) If you move that stand as it is and some of the wheels get caught on something it could rip one of the stands off easily. |
DirtyCossack Rotisserie Alternatives Jun 30 2015, 09:05 PM
Mike Bellis I would build a rolling cart. A rotisserie may mak... Jun 30 2015, 09:32 PM
madmax914 Check out Restoration Design's Youtube page, t... Jul 1 2015, 12:14 AM
mbseto Just finished working through that same decision m... Jul 1 2015, 05:50 AM
DirtyCossack I'm looking for a good dolly design. You have ... Jul 1 2015, 11:36 AM
DirtyCossack The wife gave me a go ahead to buy a rotisserie wi... Jul 1 2015, 08:32 PM
mepstein :) Jul 1 2015, 08:40 PM
mr914 Either way, door jamb braces are THE NUMBER ONE PR... Jul 2 2015, 12:29 AM
mr914 Bracing photo. Strut and pressure plate used for c... Jul 2 2015, 12:32 AM
Vacca Rabite Build a rotisserie.
You will remove the bumpers an... Jul 2 2015, 05:35 AM
saigon71 If you can find a way to fit a rotisserie in your ... Jul 2 2015, 06:38 AM
mbseto
...but after about $300...
Wow, is that ... Jul 2 2015, 06:51 AM
Amenson If anybody is in the Columbus area I found this on... Jul 2 2015, 06:51 AM
DirtyCossack Thanks for the replies. I'm really leaning tow... Jul 2 2015, 10:21 AM
stugray Buy two engine stands from HF and you have 90% of ... Jul 2 2015, 11:07 AM
Vacca Rabite You need to build it.
Many of us learned to weld b... Jul 2 2015, 11:14 AM
DirtyCossack So the rotisserie is a GO, but it has brought up t... Jul 6 2015, 05:29 PM
cary Next Time ................
https://www.jd2.com/p-9... Jul 7 2015, 06:04 AM
jpnovak Build a 914 version of this. I built one for my 9... Jul 7 2015, 07:14 AM
mbseto I've got two door braces on each side. One go... Jul 7 2015, 07:15 AM
DirtyCossack This is the good kind of worrying that leads to be... Jul 7 2015, 09:31 AM
DirtyCossack Maybe we can make "the bracing, jig, body ali... Jul 7 2015, 10:54 AM
VWTortuga336 I know this is an old post, but :agree:
I'm... Aug 6 2016, 08:40 AM
DirtyCossack
I... Aug 8 2016, 09:11 AM
Mark Henry The young lad needs to build a rotisserie I like t... Aug 6 2016, 09:12 AM
Mark Henry
The young lad needs to build a rotisserie I like ... Aug 6 2016, 09:20 AM
budk
Found the rotisserie they made for the 914 and it... Aug 6 2016, 09:33 AM
Red76 Lots of different designs for rotisseries on here.... Feb 7 2018, 04:08 PM
Red76 A couple more pics Feb 7 2018, 04:16 PM
Dutchy4U anyone who has been restoring chassis complete 914... Apr 25 2019, 05:13 PM
bbrock
anyone who has been restoring chassis complete 91... Apr 26 2019, 07:30 AM
billium01 Not to poopoo RD's rotisserie idea but it look... Apr 25 2019, 08:03 PM
David Billo
Not to poopoo RD's rotisserie idea but it loo... Apr 26 2019, 01:27 PM
Superhawk996 I've accessed all the structural elements you ... Apr 26 2019, 07:05 AM
gereed75 I am about to build a similar chassis dolly but wi... Apr 26 2019, 07:26 AM
Superhawk996
I am about to build a similar chassis dolly but w... Apr 26 2019, 07:33 AM
914werke Depending on YOUR repair (of if you plan on doing ... Apr 26 2019, 11:22 AM
mepstein I would never put a 914 on a rotisserie to fix the... Apr 26 2019, 01:49 PM
mlindner Build a dolly, as high as you want. Mine I even us... Apr 26 2019, 02:08 PM
Stuckon914 Old thread but still valid topic. How far off the ... Feb 28 2020, 05:35 PM
914forme half the width of the widest point on the chassis,... Feb 28 2020, 06:09 PM
Stuckon914
half the width of the widest point on the chassis... Feb 28 2020, 06:52 PM
VaccaRabite Having built one, here is my advice:
1) Don't... Feb 28 2020, 07:01 PM
914forme :agree: And that is why I built mine to be adjusta... Feb 29 2020, 09:22 PM
GaroldShaffer
:agree: And that is why I built mine to be adjust... Feb 29 2020, 10:01 PM
Stuckon914
:agree: And that is why I built mine to be adjus... Mar 1 2020, 06:20 PM
sixnotfour @GaroldShaffer
hijack,,, looks loowww....secrect ... Mar 1 2020, 06:51 PM
914forme
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 1 2020, 07:00 PM
sixnotfour
[b]@[url=http://www.914world.com/bbs2/index.php?... Mar 2 2020, 10:18 AM
914forme Thank you, and I miss it, but letting it go to a n... Mar 1 2020, 06:52 PM
nathanxnathan I saw this one on Pinterest, and it really inspire... Mar 3 2020, 05:49 PM
PanelBilly My Longs were in good shape, but if I knew better ... Mar 3 2020, 06:20 PM
914forme Interesting, only issue I see is that is all threa... Mar 3 2020, 06:24 PM
nathanxnathan
Interesting, only issue I see is that is all thre... Mar 3 2020, 06:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th July 2026 - 06:29 AM |
