Transmission mount options |
john77 |
Jul 1 2015, 11:24 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I need to replace the bushings on my transmission mounts, but after doing a little research I realize, as usual, there are more options than my tiny mind can handle. The car is an AX/street car that I'm slowly modifying with AX in mind.
So far I've found what appear to be a couple of stock replacements at AA: http://www.autoatlanta.com/Porsche-Transmi...1437502500.html Semi-solid mounts from WEVO: http://www.wevo.com/Products/ChassisProduc...TransMounts.htm And solid mounts from Patrick Motorsports: http://www.patrickmotorsports.com/part/914...sion-mount-set/ Anyone have any experience with any of these? Other suggestions? The car will still be used on the street, so am I right in guessing solid mounts might not be the best option? Thanks John |
Steve |
Jul 2 2015, 09:21 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I liked the sport mounts. You can also elongate the holes on the sport mounts if the holes don't match up perfectly. I am currently running the wevo mounts. I also installed a 916 gear box and thought they might help with the shifting. But since I also went with heavier springs in the rear I can't tell if it's any better.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:12 AM |
