SoCal shop to sort out my shifter, new problem, transmission leaks |
john77 |
Jun 19 2015, 03:47 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Shifting into first has started making a blood curdling grinding noise even when I come to a dead stop. My shifter is sloppy as hell - I dread any AX course where I get into 3rd as more often than not I'll downshift into 4th rather than 2nd - so I'd been considering upgrading, possibly to a Rennshift, for a while anyway. So, I'm thinking it might be time for a whole gearbox/shifter/bushing 'while I'm in there' upgrade.
Anyone in SoCal had this done and been really pleased with the results? Any shop in SoCal you could recommend? I know it's rarer than an albino saquatch, but I'd love to come out the other side of this with as precise a 914 gear change as possible. |
Chris Pincetich |
Jul 1 2015, 01:34 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
The Rennshifter is great, but stiff. Best as the "last" upgrade. Worth it! (IMG:style_emoticons/default/beerchug.gif)
After I replaced shift rod bushings, I fixed lots more slop by changing the transaxle mount bushings. They were cracked and almost falling apart, and you couldn't see the cracked rubber until you had them off and in your hand. WEVO makes a nice upgrade (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) |
john77 |
Jul 1 2015, 03:10 PM
The Rennshifter is great, but stiff. Best as the "last" upgrade. Worth it! (IMG:style_emoticons/default/beerchug.gif) After I replaced shift rod bushings, I fixed lots more slop by changing the transaxle mount bushings. They were cracked and almost falling apart, and you couldn't see the cracked rubber until you had them off and in your hand. WEVO makes a nice upgrade (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) Thanks Chris. I just finished reading the tech article on the bird about this and from the symptoms it does sound like my tranny mounts, and possibly also my engine mounts, could do with replacing. Not really confident this is a job I can do myself though. |
campbellcj |
Jul 2 2015, 06:58 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Thanks Chris. I just finished reading the tech article on the bird about this and from the symptoms it does sound like my tranny mounts, and possibly also my engine mounts, could do with replacing. Not really confident this is a job I can do myself though. Trans mounts are a very easy DIY. Engine mounts are not quite as quick/easy but also totally DIY-able. Same with the Rennshifter which is a very nice upgrade once everything else is sorted out properly. The damn linkage bushings might be the most frustrating bits truthfully. And you definitely should check/replace your clutch cable "while you're in there" and that is also one of the least-fun jobs on a 914 but again, DIY-able without much wrenching experience. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:21 PM |
