Clutch cable, .......I think |
porsche-tom |
Jul 3 2015, 08:32 AM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i just started my car and got about 2 blocks and when i depressed my clutch pedal I felt a pop and it went all the way to the floor. But if i put it to the floor i can still shift into different gears. as soon as i take it off the floor i wants to go. i would assume its the cable but its just odd that i can still shift...... sort of... ideas? tips?
Dave_Darling |
Jul 3 2015, 01:25 PM
Before you do any cutting or welding, I have a question for you.
Have you recently replaced the pedal bushings? Even if not, check the position of the clutch pedal on the cross-shaft. The roll pin that holds the pedal arm onto the cross-shaft can break (especially the ones that come with the bronze bushing sets!) and it will behave as you describe. For a while, then it won't release at all. --DD |
Lo-Fi Version | Time is now: 7th June 2024 - 05:26 AM |
