Oil drain fitting, Is something available? |
GeorgeRud |
Jul 5 2015, 03:35 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
My conversion car uses the metric sized hoses from the oil tank to the cooler, with fittings to allow for changing the oil. Does anyone make a fitting that would allow one to simply unscrew a cap or plug instead of separating the 32 and 36mm fittings? After spilling oil during today's oil change, I think there must be another way. If the hoses were AN sized, a simple T fitting with a cap would do the truck, but i don't know if anyone makes a metrick T fitting.
screenguy914 |
Jul 5 2015, 04:13 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
No drain plug on the tank? Okay.
One option is to source an AN-NPT-AN tee, then install a Fumoto ball valve into the NPT center port. You may have to find a tee with female and male AN ends to splice into an existing hose connection. They're out there. Sherwood |
Lo-Fi Version | Time is now: 8th June 2024 - 04:08 AM |
