| 76-914 |
Apr 6 2014, 06:33 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
| 76-914 |
Jul 6 2015, 02:30 PM
A million thank you's. (IMG:style_emoticons/default/pray.gif)
76-914 Electrical Question #15 Need Help Please Apr 6 2014, 06:33 PM
Mike Bellis
I'm going to have several electrical question... Apr 6 2014, 07:38 PM
Jeff Bowlsby Careful, not all model years are the same. Check ... Apr 6 2014, 09:48 PM
Tom I checked all of the schematics I can find and all... Apr 7 2014, 03:04 AM
76-914
I checked all of the schematics I can find and al... Apr 7 2014, 06:29 AM
76-914 Question #2 - Do I need to use a N/C relay off the... Apr 7 2014, 06:37 AM
Tom Kent,
Don't know why as they don't dr... Apr 7 2014, 11:37 AM
76-914 Damn, :chair: I didn't consider that the ECU ... Apr 7 2014, 02:33 PM
76-914 #3 - What is the difference between a 5AG 30A fuse... Apr 28 2014, 10:28 AM
Tom Kent,
The designations before the Amperage is f... Apr 28 2014, 12:18 PM
76-914 Had to read thru some heavy stuff for my pea brain... Apr 28 2014, 06:56 PM
Dtjaden The easiest location for switched 12v on the relay... Apr 29 2014, 08:39 AM
76-914 That could be useful info for someone that is usin... Apr 29 2014, 08:59 AM
76-914 #4- I need to tie in my alt light with the suby en... May 2 2014, 08:33 PM
Dave_Darling Green/red would be the oil pressure light, not the... May 2 2014, 10:07 PM
Mike Bellis The alternator lamp work with 2 positive leads. On... May 2 2014, 11:40 PM
Tom That red/white that goes to fuse #9 on the fused s... May 3 2014, 01:32 AM
76-914 Odd. I have one sch showing GR yet today I find th... May 3 2014, 10:10 AM
Jeff Bowlsby
Odd. I have one sch showing GR yet today I find t... May 3 2014, 11:05 AM
jrrhdmust That diagram was superseded., it was not correct. ... Jun 4 2014, 03:33 PM
76-914 #5 - If you own a 914 you know the importance of a... Jun 4 2014, 01:54 PM
ClayPerrine
#5 - If you own a 914 you know the importance of ... Aug 9 2021, 01:38 PM
76-914
#5 - If you own a 914 you know the importance of... Aug 9 2021, 02:29 PM
stugray Cut & paste from my response to another forum ... Jun 4 2014, 02:04 PM
76-914 Not completely confused, yet. :D You state that t... Jun 4 2014, 02:39 PM
Dave_Darling The short answer, which is close enough for our pu... Jun 4 2014, 03:30 PM
IGTARD :shades2: :shades2: :shades2: :shades2: Jumping... Jun 4 2014, 04:34 PM
Tom Kent,
Answer for your question about wire size fo... Jun 4 2014, 05:54 PM
76-914
Kent,
Answer for your question about wire size f... Jun 5 2014, 09:07 AM
76-914 OK, another stupid electrical question. I have not... Sep 18 2014, 07:26 PM
Spoke
If I use the single pole style, which requires th... Sep 19 2014, 05:20 AM
Mike Bellis Your steel chassis should still be a better ground... Sep 18 2014, 09:30 PM
76-914 I have one chassis to tranny ground, 2 chassis to ... Sep 19 2014, 08:44 AM
76-914 #7 - I need to connect my stock '73 back up li... Nov 7 2014, 08:30 PM
Spoke Use the negative side to switch the backup lights ... Nov 7 2014, 09:35 PM
stugray For my stock trans w/ custom harness, I just took ... Nov 7 2014, 11:52 PM
76-914
Use the negative side to switch the backup lights... Nov 8 2014, 06:41 PM
76-914 Will one of our electrical wizards help me out wit... Nov 22 2014, 02:36 PM
Tom Kent,
What are you using the neutral switch for... Nov 22 2014, 03:54 PM
76-914
Kent,
What are you using the neutral switch fo... Nov 22 2014, 07:39 PM
Spoke Nice circuit.
I redrew it to better follow the fl... Nov 23 2014, 10:57 AM
76-914 Well guess what. The Suby Computer didn't like... Nov 23 2014, 08:44 PM
Spoke
Well guess what. The Suby Computer didn't lik... Nov 24 2014, 09:55 AM
Mike Bellis I have found on my Audi conversion the ECU likes t... Nov 24 2014, 08:48 AM
76-914 Spoke, no direct connections between the ECU and r... Nov 24 2014, 09:02 PM
Tom Kent,
If the gear selector is in neutral, wi... Nov 25 2014, 03:22 AM
76-914 That is exactly what I plan to do plus check it wi... Nov 25 2014, 09:11 AM
76-914 I wanted an "in use" indicator light in ... Jul 5 2015, 09:36 PM
Tom Kent,
If you have a meter, check the resista... Jul 6 2015, 03:01 AM
Spoke
Kent,
If you have a meter, check the resist... Jul 6 2015, 05:59 AM
76-914 Over my head. <_< What is "I" in... Jul 6 2015, 08:53 AM
Spoke I is current in the LED and resistor. Here's a... Jul 6 2015, 10:41 AM
76-914 Question #10 - After someone posted a question re:... Oct 19 2015, 10:56 PM
76-914 :bump: back to pg 1. Oct 21 2015, 08:26 AM
76-914 Question #11 - I want to lower my AC fan speeds ab... Jul 13 2016, 06:05 PM
Spoke
Question #11 - I want to lower my AC fan speeds a... Jul 13 2016, 11:22 PM
914forme Video on how to draw simple schematics
Question ... Jul 13 2016, 06:19 PM
76-914
Question... Jul 13 2016, 06:51 PM
stugray
EDIT: OK, I watched the video and I already knew ... Jul 13 2016, 10:34 PM
stugray The resistor would work, but for about the same am... Jul 14 2016, 07:08 AM
76-914 Stu and Jerry; thx a million. I can't wait to ... Jul 14 2016, 07:31 AM
76-914 Post #13. I'm at a Baker's Dozen so I... Jul 27 2017, 01:57 PM
76-914 Never mind. Nailed it. I ohmed out the fuse holder... Jul 27 2017, 10:08 PM
Spoke Good find. That looks like a cheap QC connector. T... Jul 27 2017, 11:39 PM
76-914
Good find. That looks like a cheap QC connector. ... Jul 28 2017, 08:31 AM
76-914 This is one of those subjects that the more I read... Nov 20 2017, 07:38 PM
Spoke
This is one of those subjects that the more I rea... Nov 22 2017, 07:59 PM
76-914 :bump: Nov 22 2017, 09:58 AM
76-914 Thanks for answering. Electrical issues remind me ... Nov 23 2017, 10:25 AM
Spoke
Thanks for answering. Electrical issues remind me... Nov 23 2017, 11:13 AM
76-914 Went back thru it and no power from the black lead... Nov 23 2017, 01:29 PM
76-914 Hey Spoke, the switch was definitely the problem. ... Nov 24 2017, 02:36 PM
76-914 Electrical Problem #15
As stated - I'm totally... Aug 8 2021, 05:28 PM
Spoke Seems confusing as the foglight switch should not ... Aug 8 2021, 06:41 PM
76-914 Jerry, With the switch pulled out - on position - ... Aug 9 2021, 01:33 PM
Spoke
Jerry, With the switch pulled out - on position -... Aug 10 2021, 11:34 AM
76-914
Jerry, With the switch pulled out - on position ... Aug 10 2021, 04:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 09:17 PM |
