Bad day for the 914 |
57lincolnman |
Jul 9 2015, 02:10 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
Prior symptoms which progressively worsened: at full engine operating temperature (200 degrees) the idle becomes somewhat erratic at a stoplight. When I pull away in first gear, it would "stumble" or hesitate and then take-off. This would only happen after the car had been driven for about 45 min - 1 hr. Prior to that the car would operate fine.
Today: the symptoms progressed to complete failure. After driving for about an hour, the car had a very weak idle. When I gave it gas to steady out the idle it backfired twice. It progressed with practically no engine power and then finally died in the middle of intersection (of course!). There was an immediate smell of raw gas. Now it will turn over but won't fire. The car was towed to the shop. I was afraid of an engine fire so towing seemed the most prudent thing to do. Background: it has a Mallory electronic ignition with stock coil and correct spark plug wires, we've tested for vacuum leaks and there aren't any. The air flow meter was replaced with a rebuilt unit about 1 year ago (this could be the culprit). After the backfire it will certainly need to be replaced... again. The throttle body control valve unit was also replaced about two years ago. The cylinder head temp sensor unit is seated properly and tests OK. Any suggestions of where to look next are greatly appreciated. Thanks. |
davep |
Jul 9 2015, 03:31 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If it was not for the smell of raw gas I would think it was starved for fuel; possibly dirty filter, dirty sock in tank, or plugged vent creating a vacuum in the tank. Something that gradually builds up over time.
The other possibility is some ignition component overheating causing a gradually weakening spark. These items can be checked, but you need to be prepared to do a test while the failure mode is present. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:30 AM |
