Water in my gas tank, can not get away from water in my fuel |
barringtonpro |
Jul 10 2015, 06:31 PM
Newbie Group: Members Posts: 11 Joined: 21-April 13 From: NE Member No.: 15,792 Region Association: None |
So, for the past 6 weeks i have been cleaning the idle 55 jets on my two weber 40s 30mm vents. Ive cleaned out the clear jelly from the tank to were the car is drivable but cannot get it to last more than about 20 miles when the webers develops poor idle transition. The mains 130 run fine. All plugs are a light tan. After i cleaned the tank it does drives much better, but it stills does not rev through the idle circuit properly after every carb cleaning and a 20 mile drive. I'm just pumping more gas/water into my tank.
I seem to be in an impossible situation since after only two fill ups, I can see the water droplets in the bottom of the tank, again. The car runs great after i blow out the idle jet and mixture circuit. In fact i can tell which jet is clogged just by twirling it's mixture needle and not getting an engine rpm response at engine idle. So, can someone respond, please, with how they are dealing with this ethanol fuel? my search is leading me to a boating marine solution, maybe. Frank in RI 73 2.0 stock with webers |
Elliot Cannon |
Jul 10 2015, 06:54 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
If the idle jets are clogging it sounds like solid contamination rather than water. You might try taking the gas tank to a radiator place, have the tank boiled out, flush out or replace all fuel lines and install a really good fuel filter. If you are sure it's a water problem, there are some additives you can get to help with that.
Lo-Fi Version | Time is now: 8th June 2024 - 03:30 PM |
