Is this the death knell? (Oil light on when hot) |
PDXMike |
Jul 11 2015, 12:17 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I was creeping along in traffic the other day, about 89 degrees out, when my oil light started to flicker on whenever I dropped the RPM's a bit when engaging the clutch. I've always been able to make this happen if I REALLY lugged the engine down, just about stalling it, but this was unusual. It started to get the point when letting the RPM's anywhere below idle (900 or so) the light would come on, and it would even blink a little at idle. Luckily I was at my destination so I just shut everything down. I checked the oil (which was fine) but the dipstick was so hot I could barely hold it even using a crumpled up paper towel. I towed the car home and let it cool down. When I started it up to pull it in the driveway everything was back to normal. The oil light turned off quickly after start-up and would even stay off for a second or two after I stalled out the engine. How bad is this? It could be something as simple as the oil pressure sender, right? It doesn't HAVE to be horrible, does it? Or should I be thinking about what kind of great upgrades I'll make during my rebuild? -Mike |
PDXMike |
Jul 11 2015, 08:38 PM
Cooling flaps are open. Dip stick is not discolored. The oil is a LITTLE darker than it was, but not bad. Hopefully it didn't get too hot. I will change out the 10W-30 for 20W-50. I'll run the first bit of old oil through a rag to look for metal fragments. I now have the HF oil pressure gauge but not the 15/16 deep socket to take out the pressure switch. I'll get that tomorrow and see how the pressure looks. After all of that I'll do a compression check just to see what's going on. It was pretty good a couple thousand miles ago, so I'll keep my fingers crossed. Thanks for all the help!!!! Mike |
Lo-Fi Version | Time is now: 29th May 2024 - 04:06 AM |
