Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
mikedsilva |
Jul 16 2015, 05:37 PM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
I had some 5mm aluminium plates, laser cut to replace my taco plate cover...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1437089874.1.jpg) The plan is to use case sealant to provide a more permanent seal. I don't have a temp gauge... With just a very light filing around the perimeter of the plate, it is a perfect dropin fit and the bolt holes line up perfectly. Hope it works! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1437089874.2.jpg) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:12 PM |
