Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
mr914 |
Jul 16 2015, 10:07 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I personally use Devcon F
Aluminum based 2 part putty. Has same thermo expansion rates as aluminum, so with the shrinking and expanding of aluminum it won't eventually crack and separate. Without pulling the motor, I agree with the MOAT approach and sealer. My vote is caused by misplaced floor jack while lifting (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 03:38 AM |
