> Papa Smurf is finally back on track - OH NO! NOT AGAIN!, ...EDIT: it happened again!!!
naro914
post Nov 27 2014, 09:08 AM
Losing my mind...
EDIT - UPDATE: PLEASE GO TO POST #23 FOR JUNE 2015 UPDATE!!!
Hi all
Lately a handful of people have been PM'ing me asking about Papa Smurf and why I haven't posted much about what we've been doing with him. The real answer is...we haven't done ANYTHING in almost 2 years. So I thought I would post this up to explain what we've gone through to maybe help someone avoid the same issues we've had. Many of you have read the trials and tribulations we've been through with Huey...this is not quite as bad but frustrating all the same if not more...
So while you're trying to avoid all you're family obligations on this Thanksgiving morning (like I am), sit back and read this tale of woe...and give thanks to the fact that you do not have to deal with all this!!! I apologize for not having pictures of all the work that's been done. (I realized I didn't have any as I was typing. I may be able to get some later this weekend...sorry)
Keep in mind, Papa Smurf is a full on race car - not street legal at all
Back in 2011, we decided to upgrade our 2.2 liter/6. We came across a very strong and VERY fast 3.4 liter that we put in just in time for the Oct PCA race at CMP. Engine performed great, but I actually broke the suspension console on the drivers side! too much torque/power for the stock set up. So...we replaced the suspension mount points with the kit from Chris Foley and all was good.
Fast forward to Sept 2012. While at Roebling Road Raceway, Nadine heard a sound in the engine which upon examination turned out to be a spun rod bearing. The bearing was worn completely off, allowing the piston to hit a valve, break a rocker, and jam the rocker into the cam housing thus destroying the little oil supply tube in the process. So the engine got torn down, resurfaed the scored crank, replace the needed parts, and back in business. On advice from MANY race shops, we sent the crank to CCR which at the time was in California. Armondo from CCR is supposedly the "end all-be all" when it comes to Porsche cranks (more on that later). He did the work in about 4-5 weeks, good to go.
5 months later, again at Roebling, I was on lap 2 of my practice session for the PCA Club Race and all of a sudden "BANG". Uh oh.... got towed in. Back at the shop, this time, that same rod that spun last time had now broken. so...tear down, replace ALL the rods from Carillo to Pauter (long story there) send crank to Armondo - 4-5 weeks get crank back, rebuild with all new bearings, check everything out, etc. all good. Do 2 DE's and a Hillclimb after that, engine seems fine.
In June 2013, we do our first SCCA Hillclimb using Papa. On Sunday, I hear a funny noise in the engine so we stop running. It gets checked out at the shop and I'm told there's no problem, so 2 weeks later we make the 9 hr trek to Mid Ohio for the PCA Race. Again..on my second lap of my first practice - BANG. This time..its really bad. Oil everywhere. Broke a different rod which: busted a hole in the case, broke a couple valves, destroyed the GT3 oil pump, damaged a piston and cylinder, etc, etc, etc....
At this point we are obviously thinking WTF??? (OK, we've been thinking that all along but now...really????) so we look back on everything and see what we've done and what we can do different:
We had been running a stock 914/6 oil tank all this time, mounted in the normal 914/6 position. Maybe not enough oil? Knowing we had this monster GT3 oil pump ($1800 pump btw that is now toast) maybe the flow was too great, the lines too small (same -12 lines we had with the 2.2 engine...heck with the old 4 cylinder engine too to/from the cooler) and we were foaming the oil or starving the engine because not enough oil to keep up?? Nobody was absolutely certain...
So...now we needed to do a COMPLETE rebuild consisting of new case, new P&C's, new oil pump, couple new valves, this time a new crank...and of course while we were in there, we ported the heads, increasd the valves sizes, better springs, new cams, etc. We decided to back it down to a 3.2 but increased the compression and valve sizes, thus getting more HP & torque, but more easily sourced parts if need be and helped with my PCA race class....We had Armondo offset the rod journals and put bigger race bearing in (supposedly a trick way of getting more torque). All was back together and good, finally right?
Nope. First weekend out at VIR in Nov 2013, Nadine was on lap 2 (see a pattern here?) and heard that tell-tale knocking noise. Again...another spun bearing! Seriously???...this is getting absolutely crazy! This time, however, we found the problem - the oil line from the tank to the engine had collapsed on one of the bends, thus again starving the engine for oil...Can we ever catch a break???
And after all that..here's where it gets REALLY frustrating....
Just before Thanksgiving we send the crank back to Armondo, who has now moved to Texas. Our normal process is: we send the crank, he calls to say what's wrong and what it will cost, then 4 weeks or so later he gives me a final total with shipping, I overnight a check, he ships, all good. As you can see above, we've done this numerous times so we have a very good relationship going here (unfortunately). He had told me he feels so bad for the issues I've been having that he would give me a big discount and only charge for the outside work he has to pay for (nitriting) and the bearings. Fair enough. Just after New Years, I get a message from Armondo on how much I need to send him a check for. So I overnight a check and assume I would see the crank in a week.
A week goes by...no crank. I call him, leave a message. My mechanic Lou calls him...message. 2 weeks go by....I finally get him in early February!! and he says he is working on it now and I will have it by the end of Feb!! WTF? I get a sob story about how expensive the move to Texas was, and he needed my money to pay for the nitring and bearing BEFORE he got it done, not after like normal. I'm pissed, but he said he should have it done in a few weeks, I wait.
Early March...no crank. I will spare you the daily commentary of lies I got, but after 2 more months of "I'm working on it today and will ship tomorrow", I had a buddy of mine go to his place and pick up the crank, gears and bearings...at THE END OF APRIL!!! The work was only half done - no nitriting, no final polishing. I had him ship it all to Pauter and was told it would take 2-3 weeks to get the work on the crank done.
3 months later, with almost the EXACT SAME responses to my questions every week ("working on them now, will be out this week") we got everything back from Pauter in early August!!! yes...August 2014 for a spun bearing in November 2013!!
(IMG:style_emoticons/default/headbang.gif)
While we were waiting, we did major changes to the oil system: All the lines from the tank to the engine are now 1" hard lines, new oil cooler, bigger (-16) lines from the engine to the cooler, added a small oil supply feeder resevior just before the engine as recommended by Peter Dawe that holds about 2 qts immediately before entering the engine, changed some of the engine wiring to have a different start up procedure (turn the starter with no ECU/Fuel/spark until there's oil pressure, then kick on the rest of the power to start the car), redirected the engine and oil tank vents, and I'm sure much more I can't remember....
Our first weekend out was the end of October at CMP. Everything worked perfectly (yes, we made it past Lap 2!!!), though we broke a brand new CV joint. Back home, we drained the oil - no metal!! Positive sign!!!
Two weekends ago we were at very cold VIR. Good three days (except broke a shift rod...another story for another day), but engine was good. Needs dyno tuning, but performed strong and solid.
Oh, and during all this time, we added a wing and splitter....
Here are a couple video's from the weekends: First one is at CMP, second at VIR. Engine sounds good and is fairly fast, but I should have easily been able to catch the guys in front of me at VIR...needs tuning. And I'm now moving on to setting up the suspension...
And there you have it... As I mentioned above, I will get pics of some of the key parts and post them on this soon... If anyone has any specific questoins, please ask and I will help any way I can. We've learned a lot during this process.
Happy Thanksgiving everyone!! Have a safe and enjoyable Holiday Season!!!
https://www.youtube.com/watch?v=YwdeNOwLHfI
https://www.youtube.com/watch?v=MntEEKR0as4
crash914
post Jul 14 2015, 07:30 PM
its a mystery to me
I feel your pain. many $$ into a race motor, then nothing...I am hoping i can salvage something. at least 1 head.
see if you can obtain a stock 3.2 or 3.6 and just run it. That's what I am thinking, only with a 4 cyl. something reliable first, have fun then tweek it. I just can't afford the pain and $$...good luck! the women always want to give away the car...for pennies...rebuild and make it stronger!
naro914
post Jul 20 2015, 07:18 AM
Losing my mind...
QUOTE(crash914 @ Jul 14 2015, 09:30 PM) *
sorry to hear about your troubles too (IMG:style_emoticons/default/sad.gif)
As noted above, the problem with a stock engine is we won't be able to race it. Won't be competitive (as I learned this past weekend).
Nadine is just as much into this as me, so it is a little different. She's past the "sell it all" emotion now and with the fun we had this past weekend, I think we may formulate a plan at year's end. Don't know what that will be, but at least it's a step forward...
naro914   Papa Smurf is finally back on track - OH NO! NOT AGAIN!   Nov 27 2014, 09:08 AM
Mueller   Bummer about the crank..what a pain! Thanks ...   Nov 27 2014, 09:50 AM
stevegm   I saw you listed in the results for the Statesvill...   Nov 27 2014, 10:31 AM
RobW   Lots to be thankful for it sounds like. Very smoot...   Nov 27 2014, 11:09 AM
naro914   Steve Unfortunately....no on an Okteenerfest date ...   Nov 27 2014, 11:58 AM
stevegm   Steve Unfortunately....no on an Okteenerfest date...   Nov 27 2014, 01:20 PM
naro914   We are in Cornelius, just North of Charlotte. R...   Nov 27 2014, 03:34 PM
stevegm   We are in Cornelius, just North of Charlotte. ...   Nov 27 2014, 03:38 PM
Wdunster   [quote name='naro914' post='2115649' date='Nov 27...   Jul 13 2015, 04:48 AM
two914-6s   Tough luck story , awesome looking and sounding ca...   Nov 27 2014, 12:15 PM
Porschef   Sweet! Very cool. Looks like it was worth the ...   Nov 27 2014, 12:22 PM
396   A big congrats on your efforts! I've alway...   Nov 27 2014, 01:56 PM
Chris Pincetich   No shortage of drama from Huey and Papa Smurf...   Nov 27 2014, 11:52 PM
OllieG   Sounds like a major headache Bob!..glad the ca...   Nov 28 2014, 04:05 AM
naro914   Ollie It would be great if we could get Papa in on...   Nov 28 2014, 07:57 AM
r_towle   So basically, with a lot less typing, Papa don...   Nov 28 2014, 05:25 PM
stownsen914   Bob, Papa Smurf has come a long way from when I r...   Nov 29 2014, 07:25 AM
naro914   So basically, with a lot less typing, Papa don...   Nov 29 2014, 07:45 AM
r_towle   So basically, with a lot less typing, Papa don...   Nov 29 2014, 08:49 AM
naro914   [quote name='naro914' post='2116211' date='Nov 29...   Nov 29 2014, 07:33 PM
r_towle   [quote name='naro914' post='2116211' date='Nov 2...   Nov 29 2014, 08:53 PM
wndsnd   Gee, did you use Glyco rod bearings this last buil...   Nov 29 2014, 03:58 PM
naro914   Gee, did you use Glyco rod bearings this last bui...   Nov 29 2014, 07:31 PM
naro914   [color=#FF6666]OH NO....NOT AGAIN!!! ...   Jul 12 2015, 07:26 AM
billh1963   [b][color=#FF6666]OH NO....NOT AGAIN!!...   Jul 12 2015, 12:23 PM
naro914   [quote name='naro914' post='2209093' date='Jul 12...   Jul 13 2015, 06:29 AM
wndsrfr   Bob--I was at the RA event in March when your tran...   Jul 15 2015, 06:54 PM
trojanhorsepower   Bob, I am sure that everyone here feels just symp...   Jul 12 2015, 07:41 AM
RobW   Nothing worthwhile is ever easy. Your long journey...   Jul 12 2015, 07:48 AM
AndyB   Bob, I feel your pain. I have invested both time...   Jul 12 2015, 08:04 AM
brant   It's got to get better. Sorry for the terrib...   Jul 12 2015, 08:12 AM
campbellcj   That does bite and like many of us, I can relate s...   Jul 12 2015, 08:40 AM
naro914   Hey guys Thanks. There's a few issues at hand ...   Jul 12 2015, 09:06 AM
blabla914   The other issue is...like all of us here, we keep ...   Jul 14 2015, 11:18 AM
brant   Make it vintage legal You are building the motor a...   Jul 12 2015, 09:25 AM
poorsche914   I guess you could say Papa Smurf is your "bad...   Jul 12 2015, 10:11 AM
naro914   Make it vintage legal You are building the motor ...   Jul 12 2015, 10:21 AM
matthepcat   Bummer. Maybe consider engine conversion in your r...   Jul 12 2015, 10:44 AM
Mueller   Bummer. Maybe consider engine conversion in your ...   Jul 12 2015, 10:51 AM
Cairo94507   Bob- Truly every owner's nightmare. We sink t...   Jul 12 2015, 12:31 PM
stownsen914   Really sorry to hear about the trouble, Bob. My pa...   Jul 12 2015, 04:15 PM
mepstein   Take a break. Put aside some money. Get a new engi...   Jul 12 2015, 04:20 PM
naro914   I'd still like to meet you guys one day. Mayb...   Jul 12 2015, 04:25 PM
mepstein   I'd still like to meet you guys one day. May...   Jul 12 2015, 04:32 PM
naro914   Using up all my vacation time to take care of my ...   Jul 13 2015, 06:32 AM
db9146   Bob, I have no advice for you as far as Papa Smurf...   Jul 12 2015, 08:34 PM
rick 918-S   Go big Bob. Shit happens. Find a new engine builde...   Jul 12 2015, 10:29 PM
naro914   Set up a clean table when you get home and start ...   Jul 13 2015, 05:57 AM
John Jentz   THAT is certainly not happening. Nadine is adaman...   Jul 13 2015, 10:05 AM
campbellcj   Building a street engine is one thing...anyone c...   Jul 13 2015, 10:38 PM
JRust   I had a pretty shitty run myself with my 914. I kn...   Jul 13 2015, 12:41 PM
campbellcj   ^^^ As I understand, that is one reason Roger Sher...   Jul 14 2015, 06:18 PM
brant   A 914 can be pretty competitive in vintage fellas.   Jul 14 2015, 06:34 PM
914_teener   A 914 can be pretty competitive in vintage fellas...   Jul 14 2015, 07:46 PM
crash914   I feel your pain. many $$ into a race m...   Jul 14 2015, 07:30 PM
naro914   I feel your pain. many $$ into a race ...   Jul 20 2015, 07:18 AM
blabla914   Bob, I have a story for you. A friend of a friend...   Jul 15 2015, 11:06 AM
naro914   He tells us that motor runs like a banshee with n...   Jul 20 2015, 07:29 AM
Racer Chris   If you decide to move forward with the car in the...   Jul 15 2015, 11:16 AM
Chris Pincetich   Bummer! I always enjoy reading the latest (mis...   Jul 15 2015, 02:16 PM
campbellcj   And if wheel to wheel is the goal, and Porsche i...   Jul 16 2015, 06:55 PM
naro914   And if wheel to wheel is the goal, and Porsche ...   Jul 20 2015, 07:31 AM
Larmo63   It's actually easy to 'friend' Exclusi...   Jul 16 2015, 10:34 PM
bandjoey   OK. It' time for a fun break! Go get a 2...   Jul 17 2015, 06:18 PM
ThePaintedMan   OK. It' time for a fun break! Go get a ...   Jul 17 2015, 07:30 PM
naro914   [quote name='bandjoey' post='2211679' date='Jul 1...   Jul 20 2015, 07:39 AM
naro914   Hey guys...lots of good thoughts here. We are curr...   Jul 17 2015, 08:11 PM
RobW   Hey guys...lots of good thoughts here. We are cur...   Jul 19 2015, 07:22 AM
r_towle   Sell it, buy a boat. It's a whole new level of...   Jul 19 2015, 07:46 AM
naro914   Sell it, buy a boat. It's a whole new level o...   Jul 20 2015, 07:42 AM
naro914   OK, got back from the Hawk late last night, had an...   Jul 20 2015, 07:11 AM
naro914   so if any of you want updates on how things went a...   Jul 20 2015, 07:43 AM
RobW   Bob, I gave my 914 calendar to my 8 yo son yesterd...   Jul 20 2015, 09:57 AM
- Lo-Fi Version Time is now: 16th April 2026 - 10:55 AM
