another spring thread - trying on some longer 90#, took out the 100# welt meister that are much shorter-- but why is my spring not compressing equally? |
DRPHIL914 |
Jul 25 2015, 10:30 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Why is this compressing sideways?
Attached thumbnail(s) |
6freak |
Jul 26 2015, 07:49 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Why is this compressing sideways? because its to tight! is it the correct length I see a spring compressing tool,you shouldnt need that to change springs lower the bottom cup a few spots the spring will be a little sloppy until you set the car down good luck MikeC |
DRPHIL914 |
Jul 26 2015, 09:11 AM
Why is this compressing sideways? because its to tight! is it the correct length I see a spring compressing tool,you shouldnt need that to change springs lower the bottom cup a few spots the spring will be a little sloppy until you set the car down good luck MikeC I wanted to have a bit more firmness, but should have left them 2 steps lower . I want a bit higher ride height and found that I could not really do that with those springs so for now I put the 100#weltmeister springs back on. Ride is very firm, good for a/x or spirited driving. I'll keep them for later once I get my fender clearance issue figured out. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:56 PM |
