tune up, Timing |
tune up, Timing |
cpavlenko |
Jul 26 2015, 09:22 AM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I usually have my tune up done by Aircooleds Only. But now on a tight budget, and I have a ?. My Haynes manual says for timing to undo vac hose to diz, and bring the rpm to 3500. y is this. Just wondering. oh, it's a stock 1.7 FI engine.
brant |
Jul 26 2015, 11:57 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the advance weights in the distributor throw outward as rpm increases...
(increasing the total advance of to the motor) so at 3500rpm they are maxed in their travel if you time below 3500rpm, or below max advance... you are not reading an accurate number and the motor will continue to gain advance as it revs example: if you set 29degree's of advance at idle. you will have much more advance on the road as the car is at higher rpm you will then have too much advance leading to pre-detonation, higher temps, poor running, and eventually a holed piston follow the manual |
Lo-Fi Version | Time is now: 9th June 2024 - 02:40 PM |
