More Oil Temperature Questions, Hot Oil, Cool Head |
BeatNavy |
Jul 26 2015, 03:52 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
2056 with D-jet. After reading some of the recent oil temperature threads I decided I should probably check how I'm running. Don't have gauge, but I had my dipstick thermometer that was still in my old 1.7L engine. After 20 minutes of spirited driving around the neighborhood in 88 degree weather I was a little distressed to see temps on that gauge running close to 240. Yikes! Maybe not an emergency, but not optimum either. So this weekend I:
-made sure I had right amount of oil (running Joe Gibbs 20W50 right now) -made sure all the engine tin/warm air guides and heater components are in place (I had removed some of this a month ago when fixing the heat exchangers) -checked and reset timing (was probably advanced a little too much), -temporarily disconnected the thermostat cable from the top so the flaps are, in theory, always in max cooling position. None of this seemed to help. Funny thing is my head temps are normally cool. Driving around town (lots of costing and downshifting at lights) keep me in the 270-280 range, and the only time I ever really north of 300 degrees is when I'm going up a hill or if I'm running a few miles at 65 to 70 mph (and then it maybe gets to 335) out on the "freeway." Car is running great otherwise. So I'm wondering if the flaps truly are working. When I had the engine out a few months I definitely made sure, but I don't know if something is sticking or what. Right now that's my only working theory on why my head temps are cool to normal and the oil temp is warm to hot. Any thoughts? Any good way to verify flap operation without completely removing the tin (something I don't relish doing with the engine in the car). Also, engine came with this oil temp sending unit installed (below). It's definitely the source of one of my minor oil leaks. Anybody recognize it? I'd like to go ahead and install a gauge that works with this sending unit, and also see what I need to do to stop the leak. TIA, fellas. |
Harpo |
Jul 26 2015, 06:29 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one?
David |
BeatNavy |
Jul 26 2015, 07:08 PM
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one? David Hi David - I don't know what sender I'm using. It came with the engine. That's two votes for "Jonesy's taco plate." Any thoughts on what gauges (other than OEM) will work with that? It was reading about 2K of resistance ambient and then around 12 ohms when it was hot (roughly 240 degrees). Or am I better off just getting another gauge/sending unit that fits that "taco" plate? Thanks for everyone's help. Hi Beatnavy,thats getting warm....or is it,check to make sure the gauge is rated to the sendor,example 150C max gauge must use 150C sender,then get your cooling flaps/thermostat sorted ASAP,cheers. Welcome to the World, porschetub! Glad to see you made the trip over from the Bird! |
porschetub |
Jul 26 2015, 07:30 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one? David Hi David - I don't know what sender I'm using. It came with the engine. That's two votes for "Jonesy's taco plate." Any thoughts on what gauges (other than OEM) will work with that? It was reading about 2K of resistance ambient and then around 12 ohms when it was hot (roughly 240 degrees). Or am I better off just getting another gauge/sending unit that fits that "taco" plate? Thanks for everyone's help. Hi Beatnavy,thats getting warm....or is it,check to make sure the gauge is rated to the sendor,example 150C max gauge must use 150C sender,then get your cooling flaps/thermostat sorted ASAP,cheers. Welcome to the World, porschetub! Glad to see you made the trip over from the Bird! Yea thanks,thought it was time for the move,enjoying it so far,lots on here know way more about my car that i do (IMG:style_emoticons/default/smile.gif) . I have always liked VDO stuff,buy a matched gauge and sender to suit the temp range you need and go from there,you need to sort this to set a baseline for further work into your problem. Coolers......I swapped my 911 cooler for one modded for a 914/6,it had been cleaned by PO the cheap and nasty way,I had it ultrasonically cleaned and they said it was filthy,really worth doing if you can't fully sort your problem by other means,cheers. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:37 AM |
