tune up, Timing |
tune up, Timing |
cpavlenko |
Jul 26 2015, 09:22 AM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I usually have my tune up done by Aircooleds Only. But now on a tight budget, and I have a ?. My Haynes manual says for timing to undo vac hose to diz, and bring the rpm to 3500. y is this. Just wondering. oh, it's a stock 1.7 FI engine.
cpavlenko |
Jul 29 2015, 01:53 PM
One more ? When i remove the vac hose, do i need to plug the hose.
ThePaintedMan |
Jul 29 2015, 06:15 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
One more ? When i remove the vac hose, do i need to plug the hose. If you're going by the book - yes. You need to eliminate all sources of vacuum leaks. Did I miss this - is it carbed or fuel injected? Edit: Sorry, I saw that it's FI. Plug the hose coming from the plenum. Plug the hose wherever the source of vacuum is coming from (i.e. don't plug the distributor). |
cpavlenko |
Jul 29 2015, 06:26 PM
One more ? When i remove the vac hose, do i need to plug the hose. If you're going by the book - yes. You need to eliminate all sources of vacuum leaks. Did I miss this - is it carbed or fuel injected? Plug the hose wherever the source of vacuum is coming from (i.e. don't plug the distributor). Stock 1971, 1.7 fuel injected engine. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:35 PM |
