Anyone understand IR manifolds, And how they affect carb sizing ? |
got914? |
Jul 29 2015, 01:20 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Im looking at putting carburetors on a motor and trying to figure out how to select the carb size ?
Is it all based on head flow or is that only part of it ? There isnt much on the internet other than proven engine combos. Now a 250 Chevy straight 6 can run triple webers that flow 250 cfm per choke for a total of 1500 CFM, this is where i know IR manifolds work with higher CFM because obviously a single 1500 carb on a common plenum manifold would be way over carb'd. Now its a 3.3 Subaru motor H6 boxer engine. 202 CI HEad flow data found here http://speedtalk.com/forum/viewtopic.php?p=189677 States it maxs out at about 165 cfm SO I would assume I can use that as part of the calculation. Obviously you cant go higher than that or your over carbing. What are your thoughts ? |
rgalla9146 |
Jul 30 2015, 09:10 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Call PMO The Porsche carb specialists
They have reproduced the Weber triple throats with many improvements.... and in a few different sizes. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:22 AM |
