Darn wiper switch,driving me nuts, Electric pump setup a bit lost |
porschetub |
Jul 30 2015, 04:49 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I converted my wiper washer pump sometime ago because I'am using a 996 spacesaver,PO had supplyed 924 wiper switch #111953 519G with the car but not wired in,hence the questions
Pelicans how-to is a little vague in this are area,the Electroclassic EV site was some help. This is a six wire switch, 4 of those are in the wire guide...all cool,2 others are red/black and brown both look like hot wires,it seemed logical to me ? to feed the red/black into the fifth spare slot in the wire guide...it does go to a corresponding mate in the female plug on the fifth lower pin. I would seem that the spare brown wire is now redundant???,correct. The EV site mentioned that the 5th wire in the female plug isn't live so my idea is to trace it back and wire to the wiper fuse for a supply....follow me? or is that wrong?. |
Valy |
Jul 31 2015, 10:36 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
You probably stopped reading after the first post.
I ended up using the same switch as yours. The pump wire is not in the harness. Is an additional wire external tonthe harness. The extra wire in the connector is for the intermittent relay. Some people mistakenly think that can be used to power the pump but it will not work for that unchanged. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:38 AM |
