More FI fun, LM2 is smarter than me..... |
OU8AVW |
Aug 2 2015, 04:52 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I'm still finding f-ups cause by the well respected Porsche shop here in Annapolis.
1- I pulled the valve covers off the check the adjustment. They had not adjusted the valves like I asked. They were WAY off. Jake say zero lash for my cam. They were very loose. Looking at my gaskets, they were not even checked.... 2- I installed a fuel pressure gauge in the engine compartment. Fired up the car and the gauge read 40psi!!!!!! 40 f--kin' PSI So I adjusted the valves to .001" just so I could check them with a feeler. What do you know, the car ran better and it cured the high RMP lag I was feeling above 4500 rpm. Then I dropped the fuel pressure to 30psi. Now it idled much better and had ALLOT more pick up. Smooth power delivery up to mid throttle. At full-ish throttle it seemed to pop or misfire. I expect that it is running lean. Makes sense when you consider the asshat tuned the MPS with massive vacuum leaks and 40psi of fuel pressure so....... I go to hook up my brand new LM2 to do the calibration and the stupid thing won't calibrate. (IMG:style_emoticons/default/headbang.gif) I spent more time trying to figure this issue out then I did messing with the actual car. I guess I need to call Innovate tomorrow and see what they say..... |
OU8AVW |
Aug 3 2015, 07:59 AM
Why take it to a mechanic? Well, I assumed they would be able to get it perfect. I knew at some point I would have to learn all this but I wanted to be enjoying my car while I learned about D-Jet. Now I'm taking a crash coarse. My intention is to get it running 100% and go back for a partial refund. At least give the owner an earful.
I've built a few VW bugs but never an engine. This is my first Porsche, my first engine build and my first intro into fuel injection. One would think a seasoned mechanic would have something on a guy who's surfing the web for how-to info (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:29 PM |
