More FI fun, LM2 is smarter than me..... |
OU8AVW |
Aug 2 2015, 04:52 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I'm still finding f-ups cause by the well respected Porsche shop here in Annapolis.
1- I pulled the valve covers off the check the adjustment. They had not adjusted the valves like I asked. They were WAY off. Jake say zero lash for my cam. They were very loose. Looking at my gaskets, they were not even checked.... 2- I installed a fuel pressure gauge in the engine compartment. Fired up the car and the gauge read 40psi!!!!!! 40 f--kin' PSI So I adjusted the valves to .001" just so I could check them with a feeler. What do you know, the car ran better and it cured the high RMP lag I was feeling above 4500 rpm. Then I dropped the fuel pressure to 30psi. Now it idled much better and had ALLOT more pick up. Smooth power delivery up to mid throttle. At full-ish throttle it seemed to pop or misfire. I expect that it is running lean. Makes sense when you consider the asshat tuned the MPS with massive vacuum leaks and 40psi of fuel pressure so....... I go to hook up my brand new LM2 to do the calibration and the stupid thing won't calibrate. (IMG:style_emoticons/default/headbang.gif) I spent more time trying to figure this issue out then I did messing with the actual car. I guess I need to call Innovate tomorrow and see what they say..... |
stugray |
Aug 3 2015, 10:45 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have been using a LM1 for a couple of years now with no problem.
Just a datapoint |
yeahmag |
Aug 3 2015, 12:09 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Lo-Fi Version | Time is now: 7th June 2024 - 01:43 AM |
