> bmw calipers, anybody no know the models and years of the bmw calipers to put on front of teener?
funk
post Aug 3 2015, 01:28 AM
any body know the best brakes for four lugs that work well in our teeners and are in a decent price range? I figure I can get some used bmw calipers at a used parts yard If I knew the model and years instead of throwing down 400 bones for two bmw calipers at AA? any good knowledge out there on brakes?
ThePaintedMan
post Aug 3 2015, 12:50 PM
I track my car and before I began to understand the physics behind fluid dynamics and braking systems, I had already swapped out for the BMW calipers. As you'll read, if you can already lock up the tires on the car with stock brakes, then you have all the braking power you'll ever need. Add in big, sticky slicks and the situation changes somewhat.
That being said, the only advantage I can see to having the BMW calipers, is since I am running a 4-lug setup, they are the most economical, physically larger calipers available, which in theory, translates to a bigger heat sink, HOPEFULLY keeping the fluid from boiling. I have never had any signs of brake fade, but then again, the car only does 90 down the backstretch at Sebring and I have also fabricated brake ducts to the calipers themselves and I run good quality, high-temp fluid. When I go to a larger engine in the future, I'm hoping they'll hold up, but the only way to tell is to run it.
funk   bmw calipers   Aug 3 2015, 01:28 AM
porschetub   I believe the early non -vented 320i E30 ones are ...   Aug 3 2015, 02:47 AM
914Sixer   I see you are new here. Go to the Classic threads...   Aug 3 2015, 05:32 AM
Geezer914   Go to NAPA and get a set of rebuilt 320i front cal...   Aug 3 2015, 07:32 AM
Kansas 914   I don't condone this swap - though I have them...   Aug 3 2015, 08:06 AM
69telecaster   Machining is only required for mounting on later-m...   Aug 3 2015, 08:11 AM
madmax914   Before heading down the heavy BMW caliper road, ca...   Aug 3 2015, 08:58 AM
ConeDodger   Lots of effort, just to do something dumb. A prope...   Aug 3 2015, 09:08 AM
914Mels   I am very happy with the results of the BMW calipe...   Aug 3 2015, 11:54 AM
ThePaintedMan   I track my car and before I began to understand th...   Aug 3 2015, 12:50 PM
Geezer914   If you decide to go this route with all the pros ...   Aug 3 2015, 12:59 PM
boxsterfan   http://www.914world.com/bbs2/index.php?showtopic=5...   Aug 3 2015, 01:11 PM
Elliot Cannon   The BMW brakes are not a "dumb" idea at ...   Aug 3 2015, 02:20 PM
914itis   When you do the BMW upgrade do you loose your hand...   Aug 3 2015, 03:17 PM
mepstein   When you do the BMW upgrade do you loose your han...   Aug 3 2015, 03:35 PM
brant   When you do the BMW upgrade do you loose your han...   Aug 3 2015, 03:39 PM
ConeDodger   When you do the BMW upgrade do you loose your ha...   Aug 3 2015, 04:21 PM
Elliot Cannon   [quote name='brant' post='2218256' date='Aug 3 20...   Aug 3 2015, 04:48 PM
Dave_Darling   Don't give me any shit!! :rotfl: :po...   Aug 3 2015, 09:18 PM
ConeDodger   Don't give me any shit!! :rotfl: :p...   Aug 3 2015, 09:26 PM
Elliot Cannon   [quote name='Dave_Darling' post='2218416' date='A...   Aug 3 2015, 11:36 PM
ConeDodger   :teef: Nope. Got no teef... :)   Aug 3 2015, 11:45 PM
- Lo-Fi Version Time is now: 4th November 2026 - 09:51 PM
