More FI fun, LM2 is smarter than me..... |
OU8AVW |
Aug 2 2015, 04:52 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
So I'm still finding f-ups cause by the well respected Porsche shop here in Annapolis.
1- I pulled the valve covers off the check the adjustment. They had not adjusted the valves like I asked. They were WAY off. Jake say zero lash for my cam. They were very loose. Looking at my gaskets, they were not even checked.... 2- I installed a fuel pressure gauge in the engine compartment. Fired up the car and the gauge read 40psi!!!!!! 40 f--kin' PSI So I adjusted the valves to .001" just so I could check them with a feeler. What do you know, the car ran better and it cured the high RMP lag I was feeling above 4500 rpm. Then I dropped the fuel pressure to 30psi. Now it idled much better and had ALLOT more pick up. Smooth power delivery up to mid throttle. At full-ish throttle it seemed to pop or misfire. I expect that it is running lean. Makes sense when you consider the asshat tuned the MPS with massive vacuum leaks and 40psi of fuel pressure so....... I go to hook up my brand new LM2 to do the calibration and the stupid thing won't calibrate. (IMG:style_emoticons/default/headbang.gif) I spent more time trying to figure this issue out then I did messing with the actual car. I guess I need to call Innovate tomorrow and see what they say..... |
OU8AVW |
Aug 3 2015, 06:30 PM
Well, machines are only as dumb as the user and the LM2 issue was mine. I figured it out and I'm getting numbers now. It's running a little rich at idle and part load and very lean at full throttle. So in goes the center screw and out comes the keyed alen head right?
Also, it wants to die when the trhottle is released. I have a decel valve installed. Is it loosen the decel to allow more air at deceleration or is it tighten it? |
Old Yella |
Aug 3 2015, 06:52 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Well, machines are only as dumb as the user and the LM2 issue was mine. I figured it out and I'm getting numbers now. It's running a little rich at idle and part load and very lean at full throttle. So in goes the center screw and out comes the keyed alen head right? Also, it wants to die when the trhottle is released. I have a decel valve installed. Is it loosen the decel to allow more air at deceleration or is it tighten it? loose the decal valve altogether you don't need it, just another thing to dick around with. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:51 PM |
